Blur2040 Posted March 9, 2005 Share Posted March 9, 2005 Ok, I picked up my Lynx II a day or two ago, and something felt disturbingly different. The plastic cover around the screen feels like it has lost its hold. One of the corners is easily pressed down, and the others make a clicking noise when I press on them. My question is...How do I take the plastic screen magifier off the Lynx? I've read that it's easily replacable, but I don't know how! Quote Link to comment Share on other sites More sharing options...
chris_lynx1989 Posted March 9, 2005 Share Posted March 9, 2005 hello, this is rather easily accomplished by removing your battery cover and just slipping a 2.4mm flathead screwdriver(jewelers type) in to the holes where the outer left and right tabs of the battery cover normally go in.now,take your screwdriver and gently press it down in each hole to release each of the corners respectively.the opposite side of the lens will now require you to take the screwdriver and put it under one of the corners (about half an inch away from the side of it) and slide it towards the corner.it will/should easily loosen and allow the whole lens to come loose for you. to put one back in,just gently snap the thing back in one side at a time.one note to mention here! be careful,as you can crack your old or new lens at either side where the on/off or option buttons are sometimes.just take your time on it. this should go rather smoothly for you.good luck.hope this hewlps you out.--the lynxer Quote Link to comment Share on other sites More sharing options...
