leearco Posted March 18, 2005 Share Posted March 18, 2005 http://www.atariage.com/howto/composite.html i followed this mod. on my 2600Jr. there is no wires touching the solder doesnt touch any other part. HELLLPPPP. the 2600 powers on but there is no sound or pic on the screen. when i turn it on it makes a sound then the screen is blank with some lines rolling through it. aaarrrrhhhhhh when i connected the rca cables for the video and audio i used the cable wire that is in the middle (red and white). there was copper wire on the out side but i bent it back so it didnt touch anything. should i have soldered these? any guns out there that can offer advise? Quote Link to comment Share on other sites More sharing options...
leearco Posted March 18, 2005 Author Share Posted March 18, 2005 i forgot to mention that i de soldered and took out the rf slot/plug off of the board Quote Link to comment Share on other sites More sharing options...
satan165 Posted March 18, 2005 Share Posted March 18, 2005 personally i never understood how this mod could possibly work, there are pins from the stella chip that have the video sync and other parts you need to create a composite signal all wired togehter the mod on this site just shows a wire straight off that resistor, just like you said you did basically you sound like you did the mod per this site properly but i never thought that would cut it in the first place (tho it must, or it wouldnt be on the site.......i assume) heres how i did my composite video mod (i assume you are using a 2600 jr.) http://benheck.com/Games/Question3.htm Quote Link to comment Share on other sites More sharing options...
leearco Posted March 18, 2005 Author Share Posted March 18, 2005 so I was doomed from the begining? I dont know how to make circuits so Im boned. OMG Quote Link to comment Share on other sites More sharing options...
leearco Posted March 18, 2005 Author Share Posted March 18, 2005 has anyone used the guide from AA and had it work? Quote Link to comment Share on other sites More sharing options...
Tsukasa Posted March 18, 2005 Share Posted March 18, 2005 It sounds like you didn't solder the ground of the cable to the ground of the system. It won't work unless you solder the shielding of the wire to ground. Quote Link to comment Share on other sites More sharing options...
leearco Posted March 19, 2005 Author Share Posted March 19, 2005 It sounds like you didn't solder the ground of the cable to the ground of the system. It won't work unless you solder the shielding of the wire to ground. could you please explain in laymans terms. what i think you mean is the copperwire that surrounds the audio/video wires(inside the cable)...needs to be soldered to the board (ground)? what part of the board ? thanks Lee Quote Link to comment Share on other sites More sharing options...
