neotokeo2001 Posted April 30, 2005 Share Posted April 30, 2005 Need some help if you have the time. I am looking for the background color location for Vanguard and Alien. Also is there any way to speed up the control of the ship in Vanguard. It seems to move half the speed it should. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 30, 2005 Share Posted April 30, 2005 The background color is saved at 2 points in Alien...though in the disassembly, only 1 point can be located by searching for COLUBK: the bonus round...when the foreground and background are both zeroed - BTW the maze is still there LFD55: LDA $80 ;3 AND #$20 ;2 BEQ LFD8D ;2 LDA #$00 ;2 black background during bonus stage STA COLUBK ;3 To locate the other point, I just traced the SWCHB equate. In Alien, the colors will be changed to monochrome when B&W is selected (the way that it does this is by using an AND value to strip away bits IF B&W is selected)... TXS ;2 start with %11111111 LDA SWCHB ;4 AND #$08 ;2 check B&W BNE LF766 ;2 if color, skip next line LDX #$0D ;2 use %00001101 instead LF766: TXA ;2 move that bit pattern to A LDY #$00 ;2 BIT $80 ;3 BVC LF773 ;2 LDY $BF ;3 ORA #$02 ;2 AND #$F6 ;2 LF773: STA $9E ;3 save the bit pattern to $9E STY $84 ;3 LDA $E8 ;3 BNE LF78F ;2 LDX #$08 ;2 LF77D: LDA LFE3C,X ;4 get value from a table EOR $84 ;3 AND $9E ;3 strip away bits when B&W STA $F5,X ;4 CPX #$07 ;2 BCC LF78C ;2 STA VBLANK,X ;4 when X = 7 or 8, save to the color registers So all that really needs changing is the last 2 bytes in table LFE3C... LFE3C: .byte $BE; |X XXXXX | $FE3C .byte $1E; | XXXX | $FE3D .byte $5E; | X XXXX | $FE3E .byte $8E; |X XXX | $FE3F .byte $4E; | X XXX | $FE40 .byte $1E; | XXXX | $FE41 .byte $8E; |X XXX | $FE42 .byte $60; | XX | $FE43 wall color in maze section .byte $84; |X X | $FE44 screen color in maze section VERY rough disassembly + cfg... Alien.zip Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 30, 2005 Share Posted April 30, 2005 BTW by trimming out a few bytes in the program area, the table at the end can be moved (so that the game is playable on an unmodded Supercharger). Alien_Supercharger_.zip Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 30, 2005 Share Posted April 30, 2005 I'm not clear on what you had in mind for Vanguard (because making the player's ship faster would make the game too easy IMO)...but here's a rough disassembly of that game: Vanguard.zip Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 1, 2005 Share Posted May 1, 2005 Quicker ship: Fast_Vanguard.zip Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted May 1, 2005 Author Share Posted May 1, 2005 Quicker ship: 847091[/snapback] That is exactly what I was looking for. Thanks again Nukey. Quote Link to comment Share on other sites More sharing options...
