T2KFREEKER Posted October 27, 2005 Share Posted October 27, 2005 Hey all, my buddy Jack just bought a bunch of Atari Lynx II systems that don't work. All of them power up, the screen turns white, but that's it. No please insert cartridge message, no sound, nothing. Put a cart in, it does the same thing, any clues as to what's wrong? If you give me a reason and solution that works, we'll send you two systems free of charge for helping. Quote Link to comment Share on other sites More sharing options...
jum Posted October 28, 2005 Share Posted October 28, 2005 It's possible the LCD's are missing. That would certainly cause the screen to go white. Quote Link to comment Share on other sites More sharing options...
joeybastard Posted October 28, 2005 Share Posted October 28, 2005 A total guess but backlight switch problem? Quote Link to comment Share on other sites More sharing options...
T2KFREEKER Posted October 28, 2005 Author Share Posted October 28, 2005 I'm checking the Backlight switch problems out, and all have the LCD's. If it is a switch problem, I will let you know! Quote Link to comment Share on other sites More sharing options...
uji Posted November 16, 2005 Share Posted November 16, 2005 (edited) Sounds like the backlights working, but without any overlaying screen display. I'd check the ribbon connection between the pcb and lcd display, it may have become loose. Failing that there could be a loose solder connection on the brightness controller, check that out since it could be set on 100%, while decreasing it has no effect. If either of these don't work, I personally would get my continuety tester, and check all of the conponents accross the board. Could be as simple as a little resister or capacitor gone pop somewhere =) Also here's a handy set of screenshots and parts list for repairing a lynx (found while searching google): Click here I hope some of this could be handy, since I'd like to have a go myself at fixing a broken lynx, I'm quite handy with electronics =) - uji Edited November 16, 2005 by uji Quote Link to comment Share on other sites More sharing options...
Mr.collection Posted November 17, 2005 Share Posted November 17, 2005 just clean the cart slot and it should work, it seems to work the most half of my systems were broken when i bought them so i know a bit on fixing systems Quote Link to comment Share on other sites More sharing options...
lynx.repairs.page Posted January 8, 2006 Share Posted January 8, 2006 Hey all, my buddy Jack just bought a bunch of Atari Lynx II systems that don't work. All of them power up, the screen turns white, but that's it. No please insert cartridge message, no sound, nothing. Put a cart in, it does the same thing, any clues as to what's wrong? If you give me a reason and solution that works, we'll send you two systems free of charge for helping. 955460[/snapback] check the ribbon is correctly seated & no breaks in the ribbon (trace lines) Quote Link to comment Share on other sites More sharing options...
