lbaeza Posted November 7, 2005 Share Posted November 7, 2005 Hi guys I'd like to know if there's a program that can help me to convert from an image stored in a PIC file (or MIC) to a text file (MAC65 comatible) containing all the .BYTE data that represent the image... Regards Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted November 8, 2005 Share Posted November 8, 2005 The .PIC file is just straight screen bytes with the color registers included afterward aren't they? The 62 sector file? If this is just screen data then you should be able to write a simple program to take the data and put it into an include file. (Actually I did just that while messing around with the lynx cc65 compiler a while back.) My program takes raw data and builds a character array out of it into an header file. The .MIC format is compressed using a RLE format that is a little wierd (IIRC) since it can either compress horizontal lines in the picture or vertical lines. I wouldn't think it would be too complicated to get a convertor together to run on the PC though. In fact, I can imagine you could create one pretty easily by just using a 320x192 character matrix and populating it with data from the file as required and then dumping that into .BYTE statements. Quote Link to comment Share on other sites More sharing options...
miker Posted November 8, 2005 Share Posted November 8, 2005 @Shawn Jefferson No... PIC is the compressed one (e.g. with Koala Microillustrator), MIC is the other (Micropainter picture). Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted November 8, 2005 Share Posted November 8, 2005 Thanks. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted November 8, 2005 Share Posted November 8, 2005 but why transfering to .byte? why not just .incbin (or what is the mac/65 command) to include a binary file? Quote Link to comment Share on other sites More sharing options...
pps Posted November 8, 2005 Share Posted November 8, 2005 Hmm, the 62 sector file is uncompressed picture with added colors. There are raw datas of the screenmemmory, so you simply have to include the file at the screenaddress and, if you want, take the last 4 bytes to get the correct colors (Background, Col1, Col2, Col3). The compressed "PIC" is from koala micro illustrator and I don´t know how it correctly works. Perhaps there is a "color bit" followed by the number of bytes this color must be in the picture... Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 8, 2005 Share Posted November 8, 2005 If you must do it that way... 10 OPEN #1,4,0,"<picture file>":OPEN #2,8,0,"<output file>" 20 LN=1000:REM STARTING LINE # 30 TRAP 100 40 ? #2;LN;" .BYTE ";:GET #1,B:FOR A=1 TO 8:?#2;B;:GET #1,B:?#1;",";:NEXT A:?#2;B 50 LN=LN+1:REM INCREMENT LINE # 60 GOTO 40 100 POP:CLOSE #1:CLOSE #2 That should work, generating decimal .BYTE operatives, 8 per line. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted November 8, 2005 Share Posted November 8, 2005 but for what reason? 7680/8 lines of .byte statements... don'T see any practical reason for such a thing... Quote Link to comment Share on other sites More sharing options...
krupkaj Posted November 8, 2005 Share Posted November 8, 2005 Hmm, the 62 sector file is uncompressed picture with added colors. There are raw datas of the screenmemmory, so you simply have to include the file at the screenaddress and, if you want, take the last 4 bytes to get the correct colors (Background, Col1, Col2, Col3). The compressed "PIC" is from koala micro illustrator and I don´t know how it correctly works. Perhaps there is a "color bit" followed by the number of bytes this color must be in the picture... 962068[/snapback] here is the article about Koala format from BeWe. I used it when I was writing Koala load module for GEMView. http://www.cclassic.szu.pl/files/ATARI_XE/...URE%20FILES.txt Quote Link to comment Share on other sites More sharing options...
pps Posted November 8, 2005 Share Posted November 8, 2005 here is the article about Koala format from BeWe. I used it when I was writing Koala load module for GEMView. http://www.cclassic.szu.pl/files/ATARI_XE/...URE%20FILES.txt 962083[/snapback] Thanks a lot. That was a great link to me Perhaps I can now try to improve our TIF2PIC tool. Actually it´s name is wrong, cause we only allow Microillustrator pictures to be written. Quote Link to comment Share on other sites More sharing options...
lbaeza Posted November 10, 2005 Author Share Posted November 10, 2005 Hi Guys Thanks for the help so far, it's been great. I'll keep you updated with my advance in this matter. Regards Quote Link to comment Share on other sites More sharing options...
ndary Posted November 10, 2005 Share Posted November 10, 2005 Hi Guys Thanks for the help so far, it's been great. I'll keep you updated with my advance in this matter. Regards 962947[/snapback] There is a utility that can convert PIC to MIC, and other different fromats you can also use XLART to read PIC images and save them as MIC Quote Link to comment Share on other sites More sharing options...
