Almost Rice Posted November 19, 2005 Share Posted November 19, 2005 (edited) I posted some pics yesterday on this machine I just got. There is a board with Omnimon attached at C199 socket. There is a name on the a chip on the Omnimon board. Is it significant? Also the ram card has been replaced with the MM6448 card from INTEC Peripherals. It may be 64K since the front shows only 8 ram chips, but the OS still looks like 400/800 not xl/xe. I don't know what the switch if for. I will try to get better pics, but I don't feel like opening it at this time. Edited November 22, 2005 by Almost Rice Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted November 19, 2005 Share Posted November 19, 2005 (edited) The Intec MM6448 is a 16K RAM board. I'm afraid that the other pics are a little too blurred to make out. Edited November 19, 2005 by deathtrappomegranate Quote Link to comment Share on other sites More sharing options...
classics Posted November 19, 2005 Share Posted November 19, 2005 I imagine the switch is for switching between the standard 400/800 OS and the Omnimon OS. Put the switch in one position turn on the computer. Then when its at the memo pad or basic screen, hold down SELECT and tap RESET. If the Omnimon is enabled it will come back in the machine language monitor, if not it will just return to basic or memo pad. Try it again with the switch in the other position. If its the OS switch then you should only be able to enter omnimon with it in one of the positions. Steve Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 20, 2005 Share Posted November 20, 2005 Most >48K memory upgrades on the 400/800 map 4K banks at $C000-$CFFF. Try POKEing and then PEEKING 49152 to see if there's RAM present. Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted November 20, 2005 Author Share Posted November 20, 2005 Put the switch in one position turn on the computer. Then when its at the memo pad or basic screen, hold down SELECT and tap RESET. If the Omnimon is enabled it will come back in the machine language monitor, if not it will just return to basic or memo pad. Steve 968579[/snapback] Hi Steve, The Screen comes back with: Davic Young OMNIMONA3 ©1984 PC NV-BDIZC AC X Y SP GF6E4 21 0C 80 01 1DF So, is this for programming? Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted November 20, 2005 Author Share Posted November 20, 2005 Most >48K memory upgrades on the 400/800 map 4K banks at $C000-$CFFF. Try POKEing and then PEEKING 49152 to see if there's RAM present. 968621[/snapback] When I PEEK (106) I get 160. So, 160*256=40960 bytes I get the same on my 130XE. Basic Rev. C and Basic XE. I have forgotten what I needed to do to access the extra space with BXE. This page documents the PEEK Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 20, 2005 Share Posted November 20, 2005 The OS only checks for contiguous RAM when booting. So, the only way to have it see 52K of RAM would be to have no cartridge inserted. I don't know if BASICXE will recognise that type of RAM upgrade (if it's actually installed). Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted November 20, 2005 Author Share Posted November 20, 2005 I don't know if BASICXE will recognise that type of RAM upgrade (if it's actually installed). 968781[/snapback] I was referring to the 130xe. I could not get the BXE cart to work with the 400. It did not expect it to work anyway. Quote Link to comment Share on other sites More sharing options...
classics Posted November 20, 2005 Share Posted November 20, 2005 Hi Steve, The Screen comes back with: Davic Young OMNIMONA3 ©1984 PC NV-BDIZC AC X Y SP GF6E4 21 0C 80 01 1DF So, is this for programming? 968624[/snapback] Yes, its a rom debugger. The F6E4 listed is the address the program was running at when you pressed reset. You can get the documentation for the Omnimon here: http://www.strotmann.de/twiki/pub/Infothek...Mon/OmniMon.pdf Steve Quote Link to comment Share on other sites More sharing options...
