crash Posted January 11, 2006 Share Posted January 11, 2006 Greetings, My XF551 disk drive died yesterday due to a bad solder joint on the power connector. By the time I figured this out and repaired it, the board was apparently damaged. Now, when it powers on, the led flashes as usual, but I can't boot from the drive nor will it show up. Does anyone have an XF551 with a dead mech, or the main board for sale? Thanks! Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted January 11, 2006 Share Posted January 11, 2006 (edited) Make sure to re-solder the SIO connectors as these were very fragile on the XF551. This may be your problem. I had to do the same on one of mine. Edited January 11, 2006 by Guitarman Quote Link to comment Share on other sites More sharing options...
crash Posted January 12, 2006 Author Share Posted January 12, 2006 Make sure to re-solder the SIO connectors as these were very fragile on the XF551. This may be your problem. I had to do the same on one of mine. 998523[/snapback] Thanks very much! I'm not sure how I broke both SIO connectors at the same time, but re-soldering everything did the trick. Quote Link to comment Share on other sites More sharing options...
