calfranklin Posted February 5, 2006 Share Posted February 5, 2006 Which 8-bit computer/disk drive should I use the Atari C017945 power supply with? This is a 120V input and a 9V AC output. It also has the round pin connector. Can I safely use this with the 1050 drive? Quote Link to comment Share on other sites More sharing options...
classics Posted February 5, 2006 Share Posted February 5, 2006 Which 8-bit computer/disk drive should I use the Atari C017945 power supply with? This is a 120V input and a 9V AC output. It also has the round pin connector. Can I safely use this with the 1050 drive? 1012990[/snapback] That is the correct power supply for the 1050 disk drive. Steve Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 5, 2006 Share Posted February 5, 2006 Sounds right. What's the amps rating though? My 1050 PSU is 240V in, 8.5 Volts AC out at 4.5 amps. The cassette recorder also uses 9 V AC, but only at around 1.2 Amps. Quote Link to comment Share on other sites More sharing options...
miker Posted February 5, 2006 Share Posted February 5, 2006 Here's some information about this stuff: http://www.classiccmp.org/pipermail/cctalk...ary/017487.html Quote Link to comment Share on other sites More sharing options...
calfranklin Posted February 5, 2006 Author Share Posted February 5, 2006 Which 8-bit computer/disk drive should I use the Atari C017945 power supply with? This is a 120V input and a 9V AC output. It also has the round pin connector. Can I safely use this with the 1050 drive? 1012990[/snapback] That is the correct power supply for the 1050 disk drive. Steve 1013039[/snapback] Thanks for info. I'm close to trying out PCxformer with my modified ST Xformer cable and I didn't want to fry my 1050 drive in the process. Cal Quote Link to comment Share on other sites More sharing options...
calfranklin Posted February 5, 2006 Author Share Posted February 5, 2006 Here's some information about this stuff: http://www.classiccmp.org/pipermail/cctalk...ary/017487.html 1013073[/snapback] I saved this info. I have several 8-bit power supplies in my collection and frankly I have forgot which ones worked with which device. Thanks, Cal Quote Link to comment Share on other sites More sharing options...
