lucifershalo Posted February 6, 2006 Share Posted February 6, 2006 I know how to do it successfully but today I tried with more exe files and atarimax flashcart program only includes 66 .exe files out of 120 something that are in the folder, does someone have an explanation for that, did I do something wrong? thanks for your help Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 6, 2006 Author Share Posted February 6, 2006 furthermore a lot of the 66 games put on the flashcart dont work is there anything to do? any settings to change to try to make them work I found all the exe files on ape.dyndns.org:8084 and use to do the atr file the following perl maxflash.pl -8mb -exepacker -cheese -altptr -cart "C:\800xl" MyMultiCart.bin Quote Link to comment Share on other sites More sharing options...
classics Posted February 7, 2006 Share Posted February 7, 2006 Are you using Windows? If so you might want to try using the MakeMenu software, which will let you set seperate options for each EXE file. It can also tell you about any potential problems, like a game requiring OSB. Steve Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 7, 2006 Author Share Posted February 7, 2006 I have it, but how do you use it I click on the .exe but nothing are u supposed to use with something else? anyway, thanks for your help , Steve I appreciate Quote Link to comment Share on other sites More sharing options...
classics Posted February 8, 2006 Share Posted February 8, 2006 Does the program open? The first time you run it, it will ask for the location of maxflash.pl and supermenu.bin, plus the directory where you want to put the output files. Then click 'file->new cartridge' Select 'supermenu' type and the size of cartridge to make along with a name for your cartridge menu, then 'OK'. After that you can just drop EXE files from the explorer into the window to add them. Steve Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 8, 2006 Author Share Posted February 8, 2006 no the makemenu.exe does not open Quote Link to comment Share on other sites More sharing options...
classics Posted February 8, 2006 Share Posted February 8, 2006 no the makemenu.exe does not open 1015025[/snapback] Hmm, you might file a bug report on the sourceforge tracker so Eric can respond. He would probably be very interested to find out why the program will not run for you. Steve Quote Link to comment Share on other sites More sharing options...
