gobo Posted February 15, 2006 Share Posted February 15, 2006 Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 15, 2006 Share Posted February 15, 2006 Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. 1018731[/snapback] V_Blank_PM.zip Quote Link to comment Share on other sites More sharing options...
gobo Posted February 16, 2006 Author Share Posted February 16, 2006 (edited) Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. 1018731[/snapback] V_Blank_PM.zip 1018759[/snapback] Thanks for the program. Been looking for something like that for a while. In this case though I was looking for one of those ML subroutines that keep running even after you stop the BASIC Program. So if I move the paddles, the sprites will still go back and forth (horizontally) even after I hit the Break Key. Right now the program actually uses a ML routine that moves the PM's with the Joystaick even after Break is pressed. I have always wanted it to use the paddles though. The routine you gave will let me really improve the ball though. I've attached the program if you are curious. You need Basic installed. Thanks again Edited February 16, 2006 by gobo Quote Link to comment Share on other sites More sharing options...
gobo Posted February 16, 2006 Author Share Posted February 16, 2006 Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. 1018731[/snapback] V_Blank_PM.zip 1018759[/snapback] Thanks for the program. Been looking for something like that for a while. In this case though I was looking for one of those ML subroutines that keep running even after you stop the BASIC Program. So if I move the paddles, the sprites will still go back and forth (horizontally) even after I hit the Break Key. Right now the program actually uses a ML routine that moves the PM's with the Joystaick even after Break is pressed. I have always wanted it to use the paddles though. The routine you gave will let me really improve the ball though. I've attached the program if you are curious. You need Basic installed. Thanks again 1019516[/snapback] Retry attaching file............... Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 17, 2006 Share Posted February 17, 2006 (edited) Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. 1018731[/snapback] V_Blank_PM.zip 1018759[/snapback] Thanks for the program. Been looking for something like that for a while. In this case though I was looking for one of those ML subroutines that keep running even after you stop the BASIC Program. So if I move the paddles, the sprites will still go back and forth (horizontally) even after I hit the Break Key. Right now the program actually uses a ML routine that moves the PM's with the Joystaick even after Break is pressed. I have always wanted it to use the paddles though. The routine you gave will let me really improve the ball though. I've attached the program if you are curious. You need Basic installed. Thanks again 1019516[/snapback] "PROGRAM.090" on side B does what your asking. It's a "LOAD" file, although some of the others are "ENTER" files. Hmmm, go figure. Basic_Turbocharger.zip Many other routines to use on these disks. Have fun. Edited February 17, 2006 by MrFish Quote Link to comment Share on other sites More sharing options...
gobo Posted February 19, 2006 Author Share Posted February 19, 2006 Thanks alot! Hi Does anyone know of one of those old Machine Language Routines (Like the one Analog use to publish), that will let you control the position of 2 player sprites horizontally in Basic during the intterupt? Kind of like in a horizontal Pong. Or of a Basic program that acheived this? I have an old Basic game that just reads the paddle value and draws the player there but its very jerky. It would be so much better/smoother if I could find this. 1018731[/snapback] V_Blank_PM.zip 1018759[/snapback] Thanks for the program. Been looking for something like that for a while. In this case though I was looking for one of those ML subroutines that keep running even after you stop the BASIC Program. So if I move the paddles, the sprites will still go back and forth (horizontally) even after I hit the Break Key. Right now the program actually uses a ML routine that moves the PM's with the Joystaick even after Break is pressed. I have always wanted it to use the paddles though. The routine you gave will let me really improve the ball though. I've attached the program if you are curious. You need Basic installed. Thanks again 1019516[/snapback] "PROGRAM.090" on side B does what your asking. It's a "LOAD" file, although some of the others are "ENTER" files. Hmmm, go figure. Basic_Turbocharger.zip Many other routines to use on these disks. Have fun. 1019706[/snapback] Quote Link to comment Share on other sites More sharing options...
