brianrus Posted April 1, 2006 Share Posted April 1, 2006 So I read the FAQ and went down to Radio Shack, bought Part #270-1027 stupidly thinking that was all I needed to replace the fuse in my 4 Port 5200 AC Adapter.. and soon realized I didn't have the leads to attach to the board. Duh.. I've read a couple of posts that suggest going to Walmart or some MDK electronics site where the link no longer works, but haven't found a real solid answer on what to go look for. Has anyone replaced the fuse (i'm sure many people have) and if so, what did you use? Either for the fuse itself or the fuse holder, or both? It was only $3, but now those fuses I bought are a waste, unless i can find a holder with leads for them. I see the one that was originally on there were just like "caps" made by Bel on the end of the fuse with leads for soldering. Anywhere I can just find those? Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 1, 2006 Share Posted April 1, 2006 If I remember correctly, these are the one I used. Hope that helps. Mitch Quote Link to comment Share on other sites More sharing options...
kenporter Posted April 1, 2006 Share Posted April 1, 2006 So I read the FAQ and went down to Radio Shack, bought Part #270-1027 stupidly thinking that was all I needed to replace the fuse in my 4 Port 5200 AC Adapter.. and soon realized I didn't have the leads to attach to the board. Duh.. I've read a couple of posts that suggest going to Walmart or some MDK electronics site where the link no longer works, but haven't found a real solid answer on what to go look for. Has anyone replaced the fuse (i'm sure many people have) and if so, what did you use? Either for the fuse itself or the fuse holder, or both? It was only $3, but now those fuses I bought are a waste, unless i can find a holder with leads for them. I see the one that was originally on there were just like "caps" made by Bel on the end of the fuse with leads for soldering. Anywhere I can just find those? Any help is greatly appreciated. to make a pigtail fuse get yourself two pieces if bare wire and put solder on both ends of fuse and attach wire then insert into pcb. ken Quote Link to comment Share on other sites More sharing options...
Zonie Posted April 3, 2006 Share Posted April 3, 2006 Or go to an auto parts store and buy an inline fuse holder. They usually have leads on them. You can just then crimp it on with butt splices if you cannot solder. Quote Link to comment Share on other sites More sharing options...
Cobra Kai Posted April 4, 2006 Share Posted April 4, 2006 Yes, that's basically what I did. It's much easier to just attach your own leads that run externally of the adaptor and attach the new fuse(w/holder) on the outside. That's how I fixed mine, because I'm not very skilled with the soldering gun. Quote Link to comment Share on other sites More sharing options...
