carmel_andrews Posted April 11, 2006 Share Posted April 11, 2006 (edited) Just curious as to whether or not Jaskier will be incorporating an '816' mode in the next beta of atari800win+ I heard rumours that the people behind some of the pop. c64 emu's are looking at ways of adding an '816' mode to their c64 emu's I am sure it would be feasable to do this on atari800win+ or atari++ It might generate addit. interest in those looking to get '816' upgrades for their A8 setup's Edited April 11, 2006 by carmel_andrews Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 11, 2006 Share Posted April 11, 2006 I'd prefer improvement on the existing platforms. Like: - cycle exact POKEY timers (instead of scanline) - expansion schemes for Atari 800 like 64K and 1 meg. - flash cartridge emulation with write-protect on/off option. - full emulation of overscan (ie - Wide screen DMA) Plus: - option for DirectX "stretch" ie - sizable window which expands the Atari screen - play sounds when in full CPU acceleration - "normal" keyboard emulation - ie buffer keystrokes and pass them along instead of the "one key at a time" method. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted April 11, 2006 Author Share Posted April 11, 2006 I'm not sure about 800 ram expansion capability, the only programs that emulated that were v. early spartados's and v. early mydos's Other then that v. few proggies supported a800 bankswitching, conversely the xl/xe bankswitch mode wqas at least supported What I would like to see though is a resizeable window in windowed mode (like Gens offers), the options at the mo. are either too small or too big Quote Link to comment Share on other sites More sharing options...
pseudografx Posted April 11, 2006 Share Posted April 11, 2006 I'd prefer improvement on the existing platforms. Like: - cycle exact POKEY timers (instead of scanline) - expansion schemes for Atari 800 like 64K and 1 meg. - flash cartridge emulation with write-protect on/off option. - full emulation of overscan (ie - Wide screen DMA) Plus: - option for DirectX "stretch" ie - sizable window which expands the Atari screen - play sounds when in full CPU acceleration - "normal" keyboard emulation - ie buffer keystrokes and pass them along instead of the "one key at a time" method. I'd just add that it would be nice to have a "PAL emulation" mode like that in WinVICE C64 emulator. It looks really awesome and is very true to a real TV set. If that is not currently possible, at least it would be fine if Scanline and Smooth stretching modes could be turned on simultaneously. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 11, 2006 Share Posted April 11, 2006 yup, pal emulation would be nice... and i would like to test the 65816 as well even if it is not real... "just" implement a 65816 core and here we go... or how does dracos being debugged? on real machine without a real debugger? Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted April 20, 2006 Share Posted April 20, 2006 One feature that I'd really like to see is cut/copy/paste between the emulator and the pc. Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 20, 2006 Share Posted April 20, 2006 (edited) or how does dracos being debugged? on real machine without a real debugger? Yes, on a real machine. Speaking of that, I never use an emulator for development, this wouldn't be convenient. And for the ROM OS you don't need a debugger - if something is screwed, you'll sooner or later notice (provided that you actually use the machine, that is, like I do). Edited April 20, 2006 by drac030 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 23, 2006 Share Posted April 23, 2006 or how does dracos being debugged? on real machine without a real debugger? Yes, on a real machine. Speaking of that, I never use an emulator for development, this wouldn't be convenient. And for the ROM OS you don't need a debugger - if something is screwed, you'll sooner or later notice (provided that you actually use the machine, that is, like I do). Speaking of Drac OS, is there any way I can get ahold of plans and a copy of this yet (the 65816 CPU and OS upgrade)? Also, will it all work on an NTSC machine? Stephen Anderson Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 23, 2006 Share Posted April 23, 2006 (edited) Speaking of Drac OS, is there any way I can get ahold of plans and a copy of this yet (the 65816 CPU and OS upgrade)? Also, will it all work on an NTSC machine? The OS should work on an NTSC machine no problem. The files for Warp4 upgrade can be downloaded here: http://drac030.krap.pl/warp4.zip I am not a hardware guy, so I can't tell you what to do with them. Also, a warning: Warp4 is _not_ the famous and awaited F7 accelerator board. The Warp4 upgrade just provides the 65C816 CPU and 1 MB of fast linear memory, but the first 64k is still clocked at 1,77 MHz, so old programs will work identically. The Warp4 advantage is that it is equipped with linearly addressable RAM past the first 64k, and this RAM is clocked at 7,14 MHz, so it can be seen as a cheaper version of the (not yet released) F7 or the HyperSpeed XL/XE. The F7 according to the author is about to be released now. I mailed the author and got a reply at 7th March that some units will be produced "in about six weeks". Edited April 23, 2006 by drac030 Quote Link to comment Share on other sites More sharing options...
