BigBen Posted May 3, 2006 Share Posted May 3, 2006 Hi, a old/new Hardware for XL/XE computers is available. http://www.horus.com/~hias/freezer/manual/...an-eng-0.90.pdf And here you can buy it. http://www.atari-portal.net/shopabbuc/index.php BigBen Quote Link to comment Share on other sites More sharing options...
Beetle Posted May 3, 2006 Share Posted May 3, 2006 This product rocks (i saw the original one in action, but this is the even better, improved 2005 version): - freeze and resume any program or game - save frozen programs to disk and resume any time - build-in debugger - build-in oldrunner-OS, forget your translator disk - build-in DOS, happy-speeder and RAM-disks supported - use up to 480kByte of the freezer-flashrom for cartridge emulation - use up to 112kByte of the freezer-RAM for cartridge emulation and testing i'll order mine now. Beetle Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 3, 2006 Share Posted May 3, 2006 I'm going to have to get one. Write-through to RAM for $D000-$D7FF gives it the unique ability to be able to do perfect machine-state saves. Quote Link to comment Share on other sites More sharing options...
Ghost... Posted May 3, 2006 Share Posted May 3, 2006 The freezer is also a really handy tool for XL/XE developers: 1. Load editor with source code => freeze 2. Load test environment e.g. volksForth => freeze Now you can switch between the two programs..edit and test.. immediately. In sum a nice and very stable piece of hardware! best! GHO Quote Link to comment Share on other sites More sharing options...
BigBen Posted May 3, 2006 Author Share Posted May 3, 2006 If you have any question about the frezzer go to the ABBUC forum. Here you get the answer directly from the constructors. http://www.atari-portal.net/modules.php?na...e=viewforum&f=1 BigBen Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 3, 2006 Share Posted May 3, 2006 Hi! I'm Matthias Reichl, the developer of the TurboFreezer 2005 and noticed that quite a lot of you already downloaded the information present on my website. This is great, but here's a very important note: There are still some bugs in the schematics, so please be careful if you want to build a TurboFreezer by your own! The logic ICs must be 74HCTxxx types (not 74LSxxx as in the schematics) Instead of the BAT 48 diode a BAT 85 must be used. Some of the 100nF bypass capacitors (C5 and C9 in the XL schematic, C5 in the XE schematic) are missing, compared to the component layout files. And, don't worry, there really is no C6 :-) I've also added a textfile (00README.txt) to the hardware subdirectory with this information. If you've got any questions regarding the TurboFreezer, feel free to ask! so long, Hias Quote Link to comment Share on other sites More sharing options...
PacMan Posted May 4, 2006 Share Posted May 4, 2006 Just placed my order and I hope I got everything right. My German sucks big time so I did not get much of the terms for the delivery /P Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 4, 2006 Share Posted May 4, 2006 If you've got any questions about ordering a TurboFreezer it's best if you contact Wolfgang Burger directly. His email address is wolfgang <at> abbuc <dot> de. so long, Hias Quote Link to comment Share on other sites More sharing options...
BigBen Posted May 4, 2006 Author Share Posted May 4, 2006 I forget this link where you found the completely project. http://turbofreezer.horus.com Bernd Quote Link to comment Share on other sites More sharing options...
atariportal Posted May 8, 2006 Share Posted May 8, 2006 (edited) Please notice ! Wolfgang Burger is at holdays until end of may. (of course at the USA ) you can place an order, but you get possible no answere for 3 weeks. regards andreas Edited May 8, 2006 by atariportal Quote Link to comment Share on other sites More sharing options...
BigBen Posted May 14, 2006 Author Share Posted May 14, 2006 Here you can download a new preview version . http://www.atari-portal.net/modules.php?na...iewtopic&t=2246 Bernd Quote Link to comment Share on other sites More sharing options...
Beetle Posted May 27, 2006 Share Posted May 27, 2006 Hi, I got my Freezer today, and it works like a charm. I built it into my 800XL. Still needs some wrap up but it is secure in place. To freeze the computer, i push a little button beside the SIO connector. Well worth the money & work. My thanks to the guys who made this new hardware! Regards, Beetle Quote Link to comment Share on other sites More sharing options...
MacbthPSW Posted May 27, 2006 Share Posted May 27, 2006 Any idea if the hardware or software has any problems running on NTSC A8s? Quote Link to comment Share on other sites More sharing options...
Beetle Posted May 27, 2006 Share Posted May 27, 2006 Sorry, i don't know. As usual here in Germany, i own PAL Hardware only. Maybe Hias can say something abput NTSC compabitlity. I assume it should work. Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 28, 2006 Share Posted May 28, 2006 Any idea if the hardware or software has any problems running on NTSC A8s? Yes, the Turbo-Freezer works fine on both PAL and NTSC Ataris. I recently got an NTSC 800XL from Bernd (thanks a lot!) and did quite some tests. BTW: I'm currently working on a new version of the software with a lot of new features: online help, block set/copy/compare, access to RAM extensions, saving a snapshot to a boot disk creates a disk bootable without a Turbo-Freezer, dummy load (trace) of COM files, RAW (data) file load command, plus a few more minor improvements. Beta versions can be downloaded from http://www.horus.com/~hias/freezer/software/ As soon as the software is stable I'll post an announcement. so long, Hias Quote Link to comment Share on other sites More sharing options...
