BONK Posted August 8, 2006 Share Posted August 8, 2006 HMM my genesis controllers work on my 7800 but for i think it may have screwd up my master system on alien syndrome the chacter just runs to the left of the screen. is it bad to use genny controlers on the 7800? just like to know. Quote Link to comment Share on other sites More sharing options...
gdement Posted August 8, 2006 Share Posted August 8, 2006 It's perfectly fine to use Genesis controls on the 7800, the only drawback is only 1 button will work. I don't know anything about the SMS, but I've heard that 7800 controls don't work on it. If you're using 6-button Genesis controls, maybe you need to hold down the "Mode" button while you turn on the SMS. I have no idea if Genesis controls are even supposed to work on the SMS. There are some Genesis games (at least "Golden Axe II" to name one) which have control problems with the 6-button pad. Holding down the "Mode" button during startup will put the controller in legacy 3-button mode. Quote Link to comment Share on other sites More sharing options...
bcprs1 Posted August 8, 2006 Share Posted August 8, 2006 You can also use Sega Master controllers on the 7800 with one button. I also have some NES controllers that have been converted for the 7800. Both buttons will work on these controller. I'm not sure who, if anyone, still makes these though. Quote Link to comment Share on other sites More sharing options...
BONK Posted August 8, 2006 Author Share Posted August 8, 2006 I remember seeing a atari joypad. kinda looked like a nes controller not sure if those are easy to get Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted August 8, 2006 Share Posted August 8, 2006 I have a couple of SMS controllers that I want to convert when I get one of those round tuits everybody talks about. Quote Link to comment Share on other sites More sharing options...
+Psionic Posted August 8, 2006 Share Posted August 8, 2006 I remember seeing a atari joypad. kinda looked like a nes controller not sure if those are easy to get http://www.atariage.com/controller_page.ht...ControllerID=24 They aren't too hard to find, they pop up on eBay fairly frequently. Quote Link to comment Share on other sites More sharing options...
Shawn Posted August 8, 2006 Share Posted August 8, 2006 I remember seeing a atari joypad. kinda looked like a nes controller not sure if those are easy to get http://www.atariage.com/controller_page.ht...ControllerID=24 They aren't too hard to find, they pop up on eBay fairly frequently. You can buy them 24-7-365 from Best Electroincs. Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted August 8, 2006 Share Posted August 8, 2006 I also have some NES controllers that have been converted for the 7800. Both buttons will work on these controller. I'm not sure who, if anyone, still makes these though. I used to make them quite a bit. Then I started running into a problem with the diagonals not wanting to work reliably on all the controllers I converted so I just gave up and quit making them. I believe I have sold about 50-60 of them. There was also another member around here that would make them and paint them black and put a 7800 type logo on it. Quote Link to comment Share on other sites More sharing options...
jsoper Posted August 8, 2006 Share Posted August 8, 2006 I have no idea if Genesis controls are even supposed to work on the SMS. There's at least 7 US SMS games where you can't use genesis controllers (either on the Power Base or PBC) because they produce a switching signal on controller pin 7. The games are: Alien Syndrome Bomber Raid Great Volleyball Monty's Revenge Shang-hai Carmen SD Wonderboy in Monster Land Penguin Land? Tennis Ace? Quote Link to comment Share on other sites More sharing options...
Shawn Posted August 8, 2006 Share Posted August 8, 2006 2 resistors and a few cut traces and your genny pad is a fully functional 7800 pad with both buttns working. Hell you can even route the buttons on the 3 button to start and C as well so you don't have useless buttons Quote Link to comment Share on other sites More sharing options...
ataridave Posted August 22, 2006 Share Posted August 22, 2006 So, if only one button on the Genesis controller works on the 7800, what do you use for the second-part of the D-Pad, or something? I know about the Joypad, but I thought someone on this site told me that it doesn't work that well. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 12, 2010 Share Posted July 12, 2010 2 resistors and a few cut traces and your genny pad is a fully functional 7800 pad with both buttns working. Hell you can even route the buttons on the 3 button to start and C as well so you don't have useless buttons What's with all the complex (compared to this) circuitry that people keep coming up with, then, if this is all it takes? Not trying to be rude here, just trying to wrap my head around it. Why use transistors and ICs when you can just use resistors? Quote Link to comment Share on other sites More sharing options...
DarthCloud Posted July 13, 2010 Share Posted July 13, 2010 (edited) 2 resistors and a few cut traces and your genny pad is a fully functional 7800 pad with both buttns working. Hell you can even route the buttons on the 3 button to start and C as well so you don't have useless buttons What's with all the complex (compared to this) circuitry that people keep coming up with, then, if this is all it takes? Not trying to be rude here, just trying to wrap my head around it. Why use transistors and ICs when you can just use resistors? Adapter do not modify the internal circuit of the controller, so you can still use your gen pad on a Sega genesis. If you modify your pad by cutting trace then it will only work with the 7800. Going the IC route is my preferred method personally. Btw making an adapter for gen to 7800 is pretty easy and so their are many way to do it. Here mine with a standard triple 2-channel multiplexer: Edited July 13, 2010 by DarthCloud Quote Link to comment Share on other sites More sharing options...
