    62
    464
    87,044
Juno First kernel demo
Based on some discussions in "The project after the project..." I decided to test out whether a ball-based kernel would work for a Juno-First style background. My conclusion: it works and is doable with a reasonable cycle load and in a reasonable amount of code on a banked cart, and horizontal motion looks great. Vertical motion is not so great, unfortunately. The pixels seem to be horizontally "jumpy" and I don't see any good remedy for that which would still have the dots move vertically. On the other hand, the effect is still rather neat for the 2600.Each row of "Juno First" pixels takes about a scan line to set up and a full scan line to display. The setup and display code need not be run consecutively, and it is expected that in a normal kernel they would not be (do sprites for one scan line, JF setup for a scan line, then sprites for a scanline, then JF display).The 'setup' scan line has no critical timings. It needs to be done before the next WSYNC, obviously, but there's a lot of flexibility. Accumulator, Y, and flags are trashed.The 'display' scan line starts with the following code sequence:
  sty WSYNC  ldy #2  sty ENABL  JMP (JF_SB1)
That code is time-critical. If it's not necessary for pixels to go all the way to the left, it would be possible to steal a few cycles from that (depending upon how far left the pixels should go) but it would be necessary to adjust the master table. The display scan line ends with the sequence:
  sta WSYNC  jmp JF_EXIT
so the timing at JF_EXIT should be entirely predictable. THe display scan line routine trashes Y and flags, but does not affect A or X; it would be easily adaptable to use X instead of Y if necessary.EDITFixed scan-line count. Reversed left/right directions on controller. Changed darker dot color. Left difficulty switches between two vertical motion styles. I think the jerkier motion actually looks better, though it needs a lot less code.Fixed binary: Fixed source:
11 Comments
Works for me (225 scanlines, though), and does look pretty neat. I haven't ever played Juno First; reminds me of Beamrider. (Didn't Manuel already say that?)
Tried in z26 and it works. I still get a black screen in Stella 1.4.2 and 2.0. Someone should give it a go on real hardware.
I had a couple of kernels I wanted to test anyway, so I fired up the Kroko Cart. Juno First looks good on the TV (hacked to 262 lines). It's too bad the vertical movement is jumpy, but it's better than I could have done. :|
Yeah, I messed up the scan line count. Sorry 'bout that.
Hi John!
Pretty cool effect! :|
I'm not entirely sure what version you are refering to as jerky, I prefer the version the binary defaults to. (I think it's updated twice as often, with half the stepwidth or something like that?)
Any plans in continuing with this?
(It'd certainly help reducing my list of choices :|)
Greetings,
Manuel
Looks very good, although it doesn't work with Stella for me either. I actually hacked up a Juno kernel myself yesterday using a beamrider/solaris style display, and the result is posted in my blog. However, your version looks better as it is more faithful to the original.
Chris
(It'd certainly help reducing my list of choices ;))
Not really, actually. :) When I read about your thinking about JF, I figured that any good JF game ought to have the scrolling dot thingies since--regardless of whether they really affect gameplay--they are a defining aspect of the game's visuals.
I'm not really interested in writing the game myself, but wanted to if possible prevent the 'crime' of someone releasing a JF game without the dotty background.
So I'll offer you my full source code for the demo, including the code generator, gratis to anyone who wants it. I'll even do a bit of a write-up for it and offer any help you may need.
Some preliminary points:
-1- The code generator is written in QBASIC. I think QBASIC is available free on Microsoft's web site someplace; it's certainly not hard to find.
-2- Each row of dots is stored as a starting position and a string of digits; each digit is the number of cycles to the next dot, minus six. So if there should be six dots, starting at position 10, and there should be seven cycles between them except between the third and fourth where there are eight, that row would be generated as a 10 in the start array and a "11211". Note that the string is five characters because six dots will have five "gaps".
-3- Seven cycles was chosen as the minimum dot spacing because that's the time for "STA RESBL / DEY / BEQ exit". Larger spacings use STA.W or add NOPs. I use overlapping code for different dot spacings and using the above means the code generator can be pretty simple. I could have accommodated closer dots and still gotten some code overlap if I'd generated "STA RESBL / DEY / STA RESBL / BEQ exit" but since such code sequences could only exit at the BEQ the code generator would have to be more complicated.
-4- The code generator right now works by generating the strings top to bottom. When generating each string, it checks to see if the master template string W$ already contains it. If not, it appends to W$, borrowing from the end of W$ if possible (e.g. if W$ ends with "112112" and I want to add "11212", I would just add the "12" to W$ so it would end with "11211212". A better packing algorithm could probably avoid some redundancy here.
-5- Because of branching restrictions, the generated code has to be split into pages. The existing algorithm is very crude and makes no effort to find the best arrangement of code into pages.
-6- To make things quick-and-easy, I used four-byte entries for each row in the master table. This is rather expensive. If the screen is 32 dots tall (as at present), each horizontal scroll position will take up 128 bytes. Since I would expect there to be less than 256 entry points into the dot-drawing code, and since both the starting delay and number of dots are always less than 15, it should be possible to compress this into two bytes/row.
-7- At present, the generated code for each line starts with "STA WSYNC/LDY #2/STY ENABL". It may be more useful to do something like "LDA #2/STA RESBL/STA ENABL" sometime in the line before the dot line, and then starting the dot line with "STA WSYNC/STA GP0". If VDELP1 is set, this would allow for clean sprite shape updates.
-8- Because there are no delay registers for missile enables, it may be difficult to get those done without 'tearing' in the line following a dot line. I would suggest that it may be useful to compute two double-lines worth of missle data earlier in the kernel, so that immediately following a dot line the kernel can simply "LDA missiles / STA ENAM0 / ASL / STA ENAM1". If missiles are only one double-scan-line high, that might not be necessary: set up SP before invoking the dot line, then after the dot line do "cpx missiley1 / php / cpx missiley2 / php".
Let me know if you need any other assistance.
I'm getting a black screen in Stella, too. I did check out Chris' demo, and that looked pretty good already.
I played Juno First quite a bit, and I don't think the horizontal movement is very important, since you really don't move left or right very far before the grid reaches its "edge". But the vertical speed/direction of your ship is critical. (Just my 2¢.)
Hi there!
Any plans in continuing with this? (It'd certainly help reducing my list of choices ;))
Hm... hehe, let's see next if Chris will continue with it then :D
I think it'd depend on the price you have to pay for the dots. If they get so "expensive" that other, more important things of the gameplay will suffer, I'd rather choose another comprise.
Again, thanks a lot for this offer!
Wow, it's been a while since I last saw that. Back in school everyone was hacking Nibbles ;)
Ok, cool. Thanks again!
Greetings,
Manuel
