RCA switchbox solution
After visiting relatives and having to fix their antenna cables I looked at the masthead amplifier for their antenna. It amplifies the signal coming from the antenna (duh).
Because of where it is located the power and the signal travel through the same cable much like the studio ii. The voltage and current are a little different but it essentially does the same thing
