    654
    2,663
    891,607
Warlords fix for XRGB-mini
 Share
In this topic about the exciting new RGB mod for the 2600, collinp reported that the XRGB-mini had problems syncing with Warlords.
I took a quick look and noticed that VSYNC was set before the WSYNC, instead of after, which resulted in the sync signal starting late in the scanline.
I did a quick hack via Stella to swap the order. The hack resulted in the kings getting shifted to the right, but was enough for collinp to confirm that moving the VSYNC after the WSYNC did indeed fix the problem.
Today I fixed the sync and king positions by modifying the source I documented back in 2006. The source can be used to compile the original ROM or an XRGB-mini compatible build by use of the constant XRGBMINI:
; set to 1 for VSYNC fix for XRGBMINI, set to 0 for original
XRGBMINI    = 1
StartOfFrame:
       LDA    #$82        ; P-----V- P-paddles are dumped to ground, V-vertical Blank is started
   if XRGBMINI = 1
       ldx #$50           ; move left 5
       STA    VBLANK
       STA    WSYNC       ; Wait until end of 1st V-Sync scan Line
       STA    VSYNC       ; Start Vertical Sync
       STX    HMM0
       STX    HMM1
   else
       STA    VBLANK
       LDA    #$20        ; Move Left 2
       STA    HMM0        ; 3 5
       STA    HMM1        ; 3 8
   endif
ROM
warlords_xrgbmini.bin
Source
warlords.asm
Defender
defender_vsync.bin
defender_vblank.bin
 Share
This is actually cool. Been a fan of Warlords for years and one I love to break out to play against three other friends. Thanks for doing this.
