Rasta Convertor
First time I have ever taken a non-converting image, and fixed it, such that a suitable conversion is possible.
Before I reduced the detail in "certain" areas, this is the best result. Note the terrible tell-tale "horizontal banding".
Seeing that the image was struggling with two specific areas, I went in and removed most of the detail. Below will detail the before and after images.
- Reduce the image to indexed 8-bit colour, using an Atari palette file (in this case, I used the default palette from Atari 800 Win+). I chose to use no dithering at this stage
- I went in highly zoomed, and reduced problem areas down to basically 4 colours. This freed up additional colours for detail and completely eliminated any horizontal banding.
Before:
After:
Here's the final conversion:
Stephen_LaSexorcisto.xex
