New PC - upgrade, part 4
It's done!
Fortunately the leaks were all due to the fittings not being tightly seated. Unfortunately, to fix this I had to undo & redo the compression fittings on each connection. I also learned that draining the system isn't simply a matter of breaking the loop at the lowest point - water doesn't siphon out of the whole loop. So every time I disconnected a tube I'd get (distilled) water flowing out. If / when I want / need to drain the loop I'm going to do it in the bathtub and try to do it with the case upside down!
After the overnight leak test finished I then needed to drain out some of the water so I could add some coolant (which has biocide and anti-corrosion additives). But I didn't get the connections to the bottom radiator (which I had disconnected to drain the distilled water) tight, so I had to redo those again (but I think I did it better).
On the plus side, the fan noise (even at full power) is much lower (both in volume and pitch) than before. So I will call that a big win. I did some stress testing this morning and the CPU topped out at 60C with the fans at 60%. I need to do some more testing, but I have a sneaking suspicion I'm hitting a thermal clock limiter as the temperature doesn't change much even if I put the fans to 100%. This might be because I didn't apply the thermal paste correctly so there's air pockets. And to fix it I'd need to drain the loop completely so I can remove the motherboard. Ugh! OTOH, there doesn't seem to be any risk of a meltdown.
