Will it last 10.5 years too?
The PC I bought ~10.5 years ago is still up and running.
I only doubled the RAM and bought a new 4 TB HDD (which I plan to continue to use) when the 2 TB Seagate HDD died early. But the small SSD does still well:
63 TB total writes bytes means ~500 writes per byte. The wear level count is at 55, so it could last more than twice as long. I wonder if my next Samsung will do as well too.
Anyway, even though the SSD is still healthy and the CPU is also fine for most tasks, I thought it would be time for some new hardware:
- ASRock B450 Pro4 R2.0 ATX
- AMD Ryzen 7 5700G (I don't need a dedicated GPU)
- 2 x 16 G.Skill Aegis 32 GB DDR4 3200 MHz
- Samsung SSD 980 1 TB
- be quiet! Pure Power 11 400W (quite a bit oversized)
This did cost me less than 500€. Everything will go into my old BitFenix Shinobi case. Should be a quite simple task...
Edited by Thomas Jentzsch
- 2
