Reading FujiNet Date/Time into Sparta DOS 3.2g
Whenever I booted my Sparta DOS 3.2g disk was entering the current date and time manually. It was usually quick, but sometimes I didn't have the time handy. However, my Atari's (130XE and 576NUC+) both have FujiNet. When I saw on the FujiNet Wiki that you can get the current date and time from the internet (https://tinyurl.com/2r5vae5v) I decided that I had a new assembler project...
I am still (gradually) working my way through Atari Roots (https://tinyurl.com/4ea7vac8), so I have a lot to learn. I also needed to find out more about how Sparta Dos handled date and time. This led me to the Sparta DOS Construction Set, especially the R-Time 8 supplement - both found on the Serious Computerist website (https://tinyurl.com/3efmbwt8). It took a little while to figure it out, but it was a great chance to try out my MAC/65 & DDT cartridge image (via my A8picoCart). Among the things I learned:
1) DDT does not like to work on Page 6
2) You can hang MAC/65 by picking an assembly address too close to MEMLO
3) Indirect indexed addressing is very useful, and not covered in The Atari Assembler (by Don Inman & Kurt Inman). Luckily, it is in Atari Roots (though briefly).
In the end, I replaced my Date and Time calls in the STARTUP.BAT file with a FUJITD.COM file built from the following code:
10 ;LIST#D:FUJITD.ASM
20 ;
30 .OPT OBJ
0000 40 *= $4000
50 ;
4000 4C0940 60 JMP START
70 ;
80 ;--- DATA & CONSTANTS ---
90 ;
0100 ; SD TIME VECTORS
=FFC0 0110 VGETTD = $FFC0 ; GET TD
=FFC3 0120 VSETTD = $FFC3 ; SET TD
=FFC6 0130 VTDON = $FFC6 ; TD ON/OFF
=FFC9 0140 VFMTTD = $FFC9 ; GET TD FMT
=000A 0150 COMTAB = $0A ; DOSVEC
0160 ;
0170 ; TIME TO SET
0180 ; D/M/Y H/M/S
0190 ;
4003 0200 DATETIME
0210 ; DAY/MONTH/YEAR
4003 010101 0220 .BYTE $01,$01,$01
0230 ; HOUR/MINUTE/SECOND
4006 000001 0240 .BYTE $00,$00,$01
0250 ;
0260 ;-- MAIN --
0270 ;
4009 0280 START
0290 ;
0300 ; SET IODCB
0310 ;
4009 A945 0320 LDA #$45 ; APETIME ID
400B 8D0003 0330 STA $0300 ; DDEVIC
400E A901 0340 LDA #$01 ;
4010 8D0103 0350 STA $0301 ; DUNIT
4013 A993 0360 LDA #$93 ; GETTIME
4015 8D0203 0370 STA $0302 ; DCOMND
4018 A940 0380 LDA #$40 ; RECEIVE
401A 8D0303 0390 STA $0303 ; DSTATS
401D A903 0400 LDA #DATETIME&255
401F 8D0403 0410 STA $0304 ; DBUFLOW
4022 A940 0420 LDA #DATETIME/256
4024 8D0503 0430 STA $0305 ; DBUFHI
4027 A906 0440 LDA #$06 ; # BYTES
4029 8D0803 0450 STA $0308 ; DBYTLO
402C A900 0460 LDA #$00 ;
402E 8D0903 0470 STA $0309 ; DBYTHI
4031 A9EE 0480 LDA #$EE ;
4033 8D0A03 0490 STA $030A ; DAUX1
4036 A9A0 0500 LDA #$A0 ;
4038 8D0B03 0510 STA $030B ; DAUX2
403B A900 0520 LDA #$00 ;
403D 8D0703 0530 STA $0307 ; DUNUSE
4040 A90F 0540 LDA #$0F ; 15 SEC.
4042 8D0603 0550 STA $0306 ; DTIMLO
0560 ;
0570 ; GET FUJINET DATE TIME
4045 2059E4 0580 JSR $E459 ; CALL SIOV
0590 ;
0600 ;
0610 ; LOAD NEW DATE/TIME
0620 ;
4048 A200 0630 LDX #0
404A A00D 0640 LDY #$0D
404C 0650 DTPUT
404C BD0340 0660 LDA DATETIME,X
404F 910A 0670 STA (COMTAB),Y
4051 E8 0680 INX
4052 C8 0690 INY
4053 E006 0700 CPX #6
4055 D0F5 0710 BNE DTPUT
0720 ;
0730 ; CALL TD SET ROUTINE
0740 ;
4057 AD01D3 0750 LDA $D301 ;PIA
405A 48 0760 PHA ;PUSH PORT
405B 29FE 0770 AND #$FE ;BIT 0 OFF
405D 8D01D3 0780 STA $D301 ;ENABLE RAM
4060 20C3FF 0790 JSR VSETTD ;CALL SET TD
4063 68 0800 PLA ;POP PORT
4064 8D01D3 0810 STA $D301 ;RESTORE PORT
0820 ;
4067 60 0830 RTS
4068 0840 .END
It works on both of my machines, but I'd love to hear any suggestions for improvement to make the code more robust, compact, or both. I've attached the files in *.ATR format for others to play or use. Regardless, thanks for taking the time to look this over.
