ITC Colecovision Upgrades
-^CrossBow^-
I've always had a Colecovision as one of the consoles that is pretty much at the ready since first putting all my consoles together in the game room. That said, the CV is one of the consoles that doesn't get much time as compared to most of the others. It should come as no surprise that my CV is also pretty heavily upgraded. It has a dedicated composite video output amp, RGB, the +5v RAM modification, and a short delay BIOS installed into it. But even with all of that, I've never been 100% happy with how it plays. It has some odd glitching with a few games here and there, and the RGB output while looking great, It doesn't quite compare as well as some of my other RGB consoles I've done. So... what does one do in a situation like that??
Well, if you are like me, you decide that some parts your purchased sometime ago (about a year back or more), can finally be put to use into a different spare CV that I had on hand. I technically own 3 Colecovision consoles. The other 2 were all stock and would good to have on hand for not only spares, but for testing things to help rule out the upgrades installed into my main CV.  But I don't need 2 stock consoles...
One of the spares has been in my closet of doom in the game room for over a decade and would only get pulled out on occasion for testing as noted above or to move it out of the way to get to something else in the closet. But it has always worked and actually always been in good physical condition. So I it was time to finally do something with it. This blog will detail what was done on this CV that gets so little use and how it will rise and become one of the most used consoles in my setup...
The first order of business was to replace the capacitors. Replacing the capacitors in the CV isn't that big of a task compared to some consoles as there aren't a ton of them. But what is a pain is that 3 of the caps are hiding within the RF modulator housing and require removing it to replace them. But the rest are easy enough to replace.
Here is an overview of the main board with the work done. Doesn't look like much but working on CVs requires a bit more patience than other consoles as the traces and pads on the CV are very fragile and can melt off with the solder easily when trying to remove components.
Here is a picture of the bottom of the main board. The only items of interest here are the 2 capacitors near the top of the picture that I installed on the bottom of the PCB so the RF modulator doesn't have to be removed to service them in the future. You can also see the ESD protection boards that are installed on each of the two controller ports.
The ESD protection boards were designed by Jimmy at Ruggers Customs who does a TON of services on lots of retro consoles, but his speciality is the Colecovision. The ESD boards solder to the bottom of the controller port pins and are designed using rectifier diodes, to redirect any high voltage spike to the controller pins to the main ground of the console protecting the controller IC chips which, are prone to damage easily from ESD. BTW you can cause a large voltage strike from ESD by just plugging in the controllers if there is enough charge built up on your body. These ESD boards can be purchased from Console5. Here is port1's ESD board in better detail:
Here is the player 2 controller port ESD board in detail. BTW I use clipped sections of desolder braid/wick to connect the boards from the GND pad back to the nearest ground on the console on the bottom.
Here is a picture of the wiring that was done for the new rocker switch that I also installed. The switches I found will fit into the original opening and only require having to modify the switch clip anchors a tiny bit for them to be used. You can't see it in the pic, but I've got a molex connector in the wiring so I can remove the top shell easily to service the console. This is because the new switch is installed into the top shell directly. I've had these rocker switches on hand for years as I bought a handful of them from the local electronics/radio operator store. Sadly they closed up permanently this past March 2024.
The F18A has been around for over a decade but only available in small batches here and there. It is an amazing upgrade to install into a CV. It is a drop in replacement for the VDP chip and provides crisp VGA output but also adds an additional feature where it increases the ability of the console to handle more sprites on the screen at once and reduce/eliminate flicker when playing games. I also replaces the video RAM setup in the console since it has its own vram directly on the PCB. There is also a scanline option that can be enabled. It actually looks pretty good compared to some other similar scanline modes I've seen. I actually added a wire that isn't visilbe in this picture that I ran back to the channel select switch on the RF modulator. This allows me to turn the scanline feature on/off from the rear of the console vs having to manipulate the dipswitch for it on the F18A. The model shown here is the newest version known as the Mk. 1. It is much smaller than the original F18A allowing for easier installs and includes a new VGA breakout setup you can see in the back of the picture and uses a flat flex cable to send the signals from the F18A back to the VGA.
Here is a more detailed picture of the VGA breakout assembly. Again, you can see that the flat flex cable just slots into the small connector making it easy to connect up and remove the cable if the console requires future servicing. Just to the left of the VGA breakout is a new 3.5mm jack installed for audio.
Here is how everything looks at the rear of the console. You can see the VGA and 3.5mm audio jack on the left hand side here:
Here is a better detail view of the VGA output and audio jacks. I will state that the VGA was a pain to install because the breakout requires that the VGA jack be installed internally within the console. As a result, the opening for it has to be made slightly larger all the way around vs the jack so that the male cable end will fit around it properly. That required a lot of filing, little by little to make it look nice and might have taken longer than most of the other work done on the console.
It might not seem all that much work was done, but it was a full days work of work that was put into this Colecovision. After a good cleaning and some UV protectant applied (NOT ARMOR ALL!), it will now becoming the main CV used in the game room and the previous one will become the hot spare and additional testing CV console.
View the full article
4 Comments
2 hours ago, sramirez2008 said:
Thanks for sharing your work. That ColecoVision is a beauty.
Thanks!
Its funny, in the past my own consoles were usually the first time I'd worked on that system or installed the particular mod/upgrade and it would show with semi odd wiring decisions being made and stuff like that. Well, I've been going back through those older projects of mine and essentially redoing them to bring them more up to the same standards I provide to my clients. This CV is the first time I've installed this kit, but I really don't have an issue with anything I've done and so it might be one of the few consoles I ever revisit to redo anything on in the future.
That said, this particular upgrade isn't the cheapest as it is over $100 and its availability is hit in miss in that small batches get done from time to time. But the way I had to do that VGA port was a right bear and I don't know if that is something I would want to offer to my clients going forward given the labor needed to make it look right. I've also heard that there is something new on the horizon that apparently will make all of these other upgrades including Lumacode, looks like nothing. But I've not been given any specifics other than it is something semi universal to work with many different consoles, be easy to install, and offer features that don't currently exist in other upgrade options?
Be curious to see what that might be...
Hmm.
