Rewrote the dragon routines to support an animation sequence. Currently the fireball will always launch on the first pass as I discovered I used the wrong "center point" when I converted the frames. This means the following image moves left/right instead of remaining stationary when the flipped image flag is set. I'll have to run all the frames thru the converter again to fix this.
Added a wing flap sound effect.
Minor changes to the easter egg.
