bBasic - Added 10 animated bats.
Goals:
-> Further animate all 10 virtual sprites simultaneously to create circulating arial swarm.
-> Save on RAM needed for 10 enemies by mathematically generating their positions from counters.
-> Still animate player0 under joy1 control to run left and right, shoot and shield from last entry.
Design:
-> Start from last entry.
-> Implement a single X position counter that counts down to zero from 229 and then repeats.
-> The existing Ycount from 9 to 0 is kept.
-> The 10 enemy sprites are like beads on a string separated by multiples of 23 pixels horizontally and 10 pixels vertically in motion.
-> The position of a sprite is found mathematically from the main X and Y counters.
-> The X position offset from the base X counter must jump along with the enemy status (color) whenever the Y count resets.
Implementation:
main012.txt - Sorry the comments are less than stellar at this time.
Lessons learned:
-> There is a bug in version 1.0 of bBasic with data statements. If a tab precedes the data
keyword, the compilation will not include any bytes defined on that line. You must
precede a data statement with only spaces. Batari has fixed this bug for the next release.
-> The language is proving to be much more efficient than I expected. I am definitely pleased
that I have added it to my programming tools.
Recommendations for improving bBasic:
-> None
Up Next:
->Enemy shots, and maybe some collision detection.
