The Southsider
    81
    767
    138,467
16 Char Text
cd-w
I have written another text kernel which displays 16 characters. This may seem pointless, given my earlier 24-char and 28-char kernels, but it has several nice features:
  1. Uses less ZP memory (46 bytes total).
  2. Shows more lines on screen (14).
  3. Text width is a power of 2 (for easy calculations).
  4. Kernel has loads of free cycles (around 40 per scanline), e.g. could have a PF image underneath.
The main reason for writing this kernel is to allow the Juno First score table to be displayed nicely on a single line, rather than split across lines. I'm planning to integrate this, together with SaveKey support, in the next release. Note that I haven't included the level number as there is no room to store this in a single page on the SaveKey.
Chris
9 Comments
I suggest dropping the slash in the zero - it's very hard to read.
(3 initials + 3 bytes for score) X top 10 = 60 - so I gather a page is 64 bytes?
Converting the score to a 2 byte value would give you 1 byte to store the level.
Another option would be to use the top 2 bits of each initial, though that would limit you to 32 levels. If the score's last digit is always 0 then you have another 4 bits available in the last nybble.
You could also pack the three initials into two bytes by storing the letters as 5 bits, which allows for upper-case letters, space, and dot, and maybe a few extra.
It looks like positions 1-9 would fit in 13 chars, and possible even 10 if you slide the 1 and the . over.
Given this, I'm wondering if a flickering 16-char routine is really that much better than a flicker-free 13-char routine? I don't know the details of the 13-char routine but I have seen a demo of it.
"10 CDW 123456"
Yup, fits into 13! :cool:
Thanks for the suggestions. Having thought about it some more, it wouldn't actually be necessary to use a 13 char routine as the kernel for the scores could be done with sprites like this:
0--101-10  or
0---01-101
However, I think I will go the 16 character route and pack in the wave number. If each initial is restricted to 32 chars (alphabet + punctuation), then I can pack three initials into two bytes and use the remaining byte for the wave number. This would then be displayed as 10-CDW-99-000000 using the full 16 char width. I'm only planning to have 32 or 64 waves in the game so this would work nicely, and the flicker isn't a big issue given the main game :cool:
Chris
How about using 13 characters but dropping the rank? If you display 10 scores, in order from highest to lowest, do you really need to label them 1-10?
But if you do that, you don't get the satisfaction of seeing your name next to #1. :cool:
How about using the Playfield and Ball to draw a nice big digit behind the score table showing the player's rank from the last game (if applicable)? A 7-segment-style digit could be done without requiring any CPU cycles during the score-digit-display kernel.
