7800 Fine Scrolling
I’ve recently been doing some research into how scrolling games work on the 7800. I have created a demo program that shows a method for doing horizontal and vertical fine scrolling controlled with the player one joystick. I’ve tested this program on an emulator but on the actual hardware. The attached ZIP files contains the source and binary that can be used with an emulator.
Display List
The display list for the demo consists of 24, 8 line high regions. Each region will display 41 characters in the 320D mode using indirect graphics. Each region has two DL entries one to display the first 20 characters, the second to display the remaining 21. Two DLs are needed because you can’t display more the 32 characters with a single DL.
Horizontal Scrolling
The horizontal scrolling turns out to be pretty easy because of the way the 7800 handles wrap around of the graphics. A horizontal position of 0 – 159 is visible on the screen but anything beyond 159 won’t be displayed. If you position a graphic with an hpos just below 255 the beginning of the graphic won’t be displayed but the rest will. So to do horizontal scrolling it’s simply a matter of changing the hpos of the two dl entries on each line. You will notice that the second DL entry has 21 characters instead of 20. This is necessary because even though the screen is 40 characters wide 41 different characters will be displayed during scrolling with partial characters at either end of the line.
Vertical Scrolling
Vertical scrolling is a little trickier. Here we need to end up with partial characters at the top and bottom of the screen during scrolling. The cropping of the top row can easily be handled by varying the height of the top region between 1 and 8 lines. As the top region gets smaller the bottom region will needs to get bigger so its height is set to (8 – top region height). Simply changing the height of last region won’t actually give us the result we need, because as the region get smaller the top of the characters will be cropped off not the bottom. To compensate for this we need to adjust the character base pointer for just the last zone. For each line smaller we make the last region we need to move the character base pointer up one page. We can achieve this using a display list interrupt on the last zone to set the modified character base, then another one in the next zone to get it back to the default.
Course Scrolling
Note that what I am demonstrating in this program is just fine scrolling. Once I have scrolled a full character width or height in a specific direction I reset the scrolling back to the start of the character. It gives the appearance of continuous scrolling but I am really just repeatedly scrolling over the same characters. You could layout the entire character map for a screen in RAM or ROM then scroll the screen over that map. When you reached the end of a fine scroll you would reset the scroll and then update all the memory pointers in the display list to course scroll to the next row of column of the map.
- 1
