Planet Builder - Starfield Trouble
I loaded Planet Builder on my Kroc Cart and the starfield does not have the smooth movement that I want. Not sure where the problem is. Here is my Main Screen kernal where I call the subroutine DrawStars. I use LDA StarTable,Y to turn off and on idividual stars. Any insight into this problem would be appreciated. I'm using FILL_NOPs at Line 777 to pad the code
MainScreen SUBROUTINE JSR SixDigitDisplay ;Ship Movement ;--SwitchDraw ; TopLine == top line of sprite ; BottomLine == bottom line of sprite ORed with $80 ; requires scanline counter < $80 (i.e., 128 lines, though you ; can get around this by interlacing your graphics) LDY Mineral_Truck ; Calculate SwitchDraw Variables SEC LDA Ship_YPos STA PSWITCH SBC #C_SHIP_HEIGHT STA PEND ; Subtract Height For SwitchDraw Routine LDA #<Sprite_Data0 SBC PEND STA Ship_Ptr LDA Truck_Tab,Y SBC PEND STA Ship_Ptr+2 ;Continue to Calculate SwitchDraw Variables LDA PEND ORA #%10000000 STA PEND LDX #0 LDA Ship_XPos JSR bzoneRepos STX PF0 ;prevents artifact after (Restore black border..) sleep 10 SEC LDA Ship_ColorPtr SBC Ship_YPos CLC ADC #C_SHIP_HEIGHT-#1 STA Ship_ColorPtr STA WSYNC STA HMCLR LDX #1 SEC LDA Ship_XPos CMP #12 BCS NoAdjust ADC #161 NoAdjust SBC #8 JSR bzoneRepos STA WSYNC STA HMCLR JSR DrawStars LDA #QUAD_SIZE_MISSILE STA NUSIZ0 LDA #SILVER ;Ball(meteor)is color of playfield STA COLUPF TSX ; Transfer stack pointer to X STX SavedStackPointer ; Store it in RAM LDX #ENABL TXS ;--------------------------------------------------------------------------------------------------- ;Top Kernal ;Begin Ship draw loop ;LDY #C_KERNAL_HEIGHT +#C_SHIP_HEIGHT - #1; LDY #127 ;was 151 (Switchdraw maximum height is 127) STA WSYNC ;0 ;--------------------------------------------------------------------------------------------------- ShipLoop ; Draw Sprite (SwitchDraw) CPY PSWITCH ; 3 = 3 BPL PSwitch ; 2/3 = 5 LDA (Ship_Ptr),Y ; 5 = 10 STA GRP0 ; 3 = 13 LDA (Ship_Ptr+2),Y ; 5 = 18 STA GRP1 ; 3 = 21 writes must be finished before cycle 22 to avoid tearing PContinue ;Color for Ship loaded below STY COLUP1 ; 3 = 24 ;Color for Ship loaded below STX COLUP0 ; 3 = 27 ;Draw Truck = 27 ;--------------------------------------------------------------------------------------------------- ;DrawMissile TYA ; 2 = 2 assuming y contains the scanline SBC Missile_YPos ; 3 = 5 carry must be 1 (else use DCP) ADC #C_MISSILE_LENGTH ; 2 = 7 LDA #2 ; 2 = 9 ADC #$FF ; 2 = 11 carry is always set! STA ENAM0 ; 3 = 14 bit 1 depends on the carry after ADC ;EndMissileLoop ;Draw Stars ;Y Has Scanline 127 LDA StarTable,Y ;5 = 19 STA ENAM1 ;3 = 22 waste a cycle ;Drawing Missiles =22 ;--------------------------------------------------------------------------------------------------- ;DrawMeteor CPY Meteor_YPos ;3 Assumes Y is your kernal line counter PHP ;2 LDX #ENABL ;2 TXS ;2 ;EndMeteorLoop ;Drawing Meteors =9 ;--------------------------------------------------------------------------------------------------- ;27+22+9=58 ;Load Color for RCV LDA (Ship_ColorPtr),Y ;5 = 63 TAX ;2 = 65 NOP ;2 = 67 NOP ;2 = 69 DEY ;2 = 71 CPY #48 ;2 = 73 BCS ShipLoop ;3 = 74 ;--------------------------------------------------------------------------------------------------- ; SwitchDraw Routines PSwitch ; 6 bne PWait ; 2/3 = 8 LDA PEND ; 3 = 11 STA PSWITCH ; 3 = 14 SLEEP 4 ; 4 = 18 bcs PContinue ; 3 = 21 PWait ; 9 STA HMCLR ; 3 = 12 SLEEP 6 ; 6 = 18 BPL PContinue ; 3 = 21 EndShipLoop if (>ShipLoop != >EndShipLoop) echo "WARNING WARNING WARNING WARNING: ShipLoop Kernel crosses a page boundary!" endif ;--------------------------------------------------------------------------------------------------- LDA THREE_MED_COPIES ;three buildings STA NUSIZ1 ;place here to minimize vertical missile stretch LDX SavedStackPointer TXS
And here is the Draws Stars Subroutine
DrawStars SUBROUTINE LDA Star_XPos LDX #3 JSR bzoneRepos STA WSYNC STA HMCLR LDA #$70 ;this value is important for the effect STA HMM1 STA WSYNC STA HMOVE SLEEP 16 LDA #$60 STA HMM1 ;this is the tricky part RTS
