atari project pictures
just a few pics... still in progress.
First attempt... trying to correct a few things
Scrapped the first and restarted on a new 2600 board. (I've got 15 or so 2600 boards I can go through if I need to LOL
Close up of the bottom right-hand side of the board.
(connected to pins 2, 5, 7,
This is the left hand side of the board (bottom)
Close up again...
This is the top left hand side of the board. (Eventually the place where I tie-in the Select and Reset wires)
If cutting too close to the edge of the cart connector is a problem, this is the area I am concerned with. Someone check out the otherside of the board. there are two things (res caps... ) that concern me. It is possible my problem is right here. Not really sure though.
If you notice, I have only connected the wires that require audio/video out... and then connected the wires that are needed to get the 4X4 to work. I haven't connected the controls, as I'm not concerned with those. they tend to be the easiest part of all of this. I'll get that AFTER I can fix this part.
I also have a Casio Model EV-660B that I will be using. Ready to go on that as well... just waiting to get past this hurdle and I'm about to restart again on a new board. LOL
Got any tips, advice, see any issues, please let me know.
7 Comments
