Z3.C - debugged
It works! I found the bug in the parsing routine (dumb error on my part). I'm going to call this chapter complete.
The next chapter is to create z3.spin based on this code. I/O will probably be based on a serial terminal interface. And it will run catseye.z3, which is small enough to fit in HUB RAM (hopefully), so no SD I/O. The objective is to do as little as possible other than porting the code from C to SPIN.
1 Comment
