ivop's Blog
    16
    31
    48,274
Reverse Engineering the Macro-Assembler XE File Format
ivop
 Share
On the Atari 8-Bit Forum, Heaven/TQA asked for help with retrieving an ASCII version of his demo sources in Macro-Assembler XE format. Because I recently wrote a detokenizer for Mac/65, I thought it'd be fun to try this file format too. Here's the result. It successfully detokenizes all the sample .ASM files I found in his zip-file, but I'm sure some functionality is missing (at least three assembler directives). If you stumble upon files that fail, please send them to me and I'll update the detokenizer. Or send me the Macro-Assembler XE manual, so I can add all directives at once.
Compile with: gcc -O3 -std=c99 -W -Wall -o demaxe demaxe.c
Run with: ./demaxe fubar.asm > fubar.txt
Should also work under cygwin/mingw32. If there's interest in a Windows-binary, I might setup a cross-compiler. Leave a message below :)
demaxe.c.gz
 Share
