Cougar Stereo Install pt.3
Woofer cutout - that's an 11" square with 3" corner radii.
There's the port, 14.5" X 2" X 16.75". Sides and bottom of box is used to form the port.
Finally ready to make the woofer cutouts.
It's starting to look like a box now.
Close-up of opening, showing the port. Note all panels sit inside dados and are completely sealed.
Another front shot.
Holes are drilled for the eight #10-32 T-Nuts.
The T-Nuts press in easily with this heavy duty 3" c-clamp.
All pressed in. This woofer will be held firmly and can be removed without damaging the box.
All that's left is some minor Bondo along the edges / joints and stretching the black carpet. The subs will be wired as a single 2ohm load (each sub has dual 2-ohm voice coils).
1 Comment
