Regarding Rotary Controllers
Just in case people are sitting on the fence over getting one, I would recommend that you source one with at least 72 clicks per spin (ie, Chaos Reigns)
The game will allow you to calibrate to whatever you get, but higher is better.
As for button/rocker - I can't comment. I don't own one of the rocker type controllers, so it's not been tested with it. It looks like it works ok with tempest, but the controls are significantly different for Rebooteroids. You have to hold a button for thrust - not sure if you could hit the other buttons while doing that, and if fire or hyperspace is the opposite direction on the rocker... well, I don't see how you can push it in both directions at once.
Anyway, as previously stated, we're building and testing against Chaos Reigns as the stock standard spinner. I can promise you won't go wrong with one of those.
We also have a few more spinner games in the pipeline for future releases, so it should get more use than just Rebooteroids and Tempest - plus I think Impulse! will be using them?
4 Comments
