I've made a variation of my sprite converter tool that will convert a sprite AND create a vector version at the same time. This will make it much easier for me to process all the forthcoming images.
http://www.spiceware...ari/vector8.php
To use it, enter a GIF image that's available online via URL
Tell it which color is the background color, color numbers are in the top-right, and an image using those numbers is at the bottom. (Tip: click CHANGE COLORS if screen color conflicts with any sprite color)
and get the results
The way the vector image is created is to check the neighbors (up/down/left/right, ignoring diagonals) of each pixel. If all 4 neighbors are on, then turn the pixel off.
Next I need to make a converter that merges the vector routines with the 2x sprite routines from my Two Color converter (which I used for the dragon graphics in Medieval Mayhem).
