Linksys WRT54G v4 firmware confusion
A while back the wall wart for my Netgear wifi router died. I borrowed the one for my external drive as a temporary replacement, but I wanted a more permanent solution. This weekend was the community garage sale and I scored a Linksys WRT54G v4 for $5. This is the router which started the open firmware revolution, but I'm not sure I want to join the revolution.
The problem is I'm more into stability and easy to use than features beyond what the stock firmware provides. Well, there are two features which would be nice to have:
1. IPv6 firewall / tunnel blocking
2. separate guest wifi (for the Nintendo DS which only supports WEP)
But I look at the different options and I'm finding it very difficult to determine what I should be downloading...
- Tomato doesn't have guest wifi
- OpenWRT is has guest wifi, but it looks like not in the current release with the built-in open source driver
- dd-WRT has guest wifi, but is a monolithic install and the current "stable" version is buggy
3 Comments
