- Menu changed so only option name is highlighted. This was done so it's easier to see the color values when you're changing them.
- highlight is now a white gradient, START changed to a red gradient so you can tell when it's selected
- fixed a bug where an extra grey selection would show up before multicolor when using joystick-right on the color option.
- luma value changed to 8 for monochrome asteroids. Previously it was 14. This should make flicker less noticeable.
- Ship explosion slower and has an extra invisible frame at the end. This was done so that any shots in the air can finish their travels so the other player doesn't score points off your shots.
- Fixed it so game won't end if you lost your last ship but your final shots scored you an extra ship.
ROMs
Source
4 Comments
