+atari2600land Posted January 24, 2007 Share Posted January 24, 2007 In case you haven't read my blog lately (or you don't read blogs for some reason), here's a little game I'm working on called Mr. Frog. So, what do you think? mrfrog012407.bas.bin mrfroginstructions2600.txt Quote Link to comment Share on other sites More sharing options...
jbanes Posted January 24, 2007 Share Posted January 24, 2007 So, what do you think? I think you need to replace the music. (Right hand) C E G E F D E (Left hand) C A F A G B C (Right hand) C E G E F D E (Left hand) C A F A G B C (Sorry, couldn't resist. ) I think it's actually your best platformer yet. It still needs some tweaking, but it's a great start. A few suggestions: 1. Allow the frog to walk slowly. The jumping is great, but it would be nice to be able to adjust the position of the frog without hopping. Think of Frog Pond on the FB2. 2. Fix it so that you can't hop halfway up walls. 3. Fix the bug where the frog can keep jumping on the final pad to drive up the score. 4. After the final pad, Mr. Frog falls through the floor. Is this supposed to happen? 5. Replace the music with "Mr. Frog is full of hops." Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 24, 2007 Author Share Posted January 24, 2007 (edited) 1. Allow the frog to walk slowly. The jumping is great, but it would be nice to be able to adjust the position of the frog without hopping. Think of Frog Pond on the FB2. 2. Fix it so that you can't hop halfway up walls. 3. Fix the bug where the frog can keep jumping on the final pad to drive up the score. 4. After the final pad, Mr. Frog falls through the floor. Is this supposed to happen? 1. Will do. 2. This is a far-from-done version, as you know, and this'll be taken care of. 3. Again, this is an early prototype, and I'll be adding more and more levels to this game. I'll take care of this bug once I stop adding new levels. 4. What do you mean? At the final pad, doesn't #3 happen? So I take it you don't like the title screen music? Edited January 24, 2007 by atari2600land Quote Link to comment Share on other sites More sharing options...
jbanes Posted January 24, 2007 Share Posted January 24, 2007 1. I've never played Frog Pond. Is there a ROM somewhere for an emulator? The original prototype can be found here. 4. What do you mean? At the final pad, doesn't #3 happen? On the final pad you can jump up and down rather than being held in place while the counter operates. By jumping up and down you can make it operate more than once. So I take it you don't like the title screen music? Naw, I'm just picking on you. Your title "Mr. Frog" reminds me of a song taught in basic piano lessons. It's called "Mr. Frog is full of hops" and is incredibly simple to play. (You can see the notes in my previous post.) The words that accompany the song are: "Mis-ter frog is full of hops, That's be-cause he nev-er stops! When he leaps he sel-dom flops, That's be-cause he's full of hops!" I'm sure that a lot of folks around here probably recognize the tune. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 25, 2007 Author Share Posted January 25, 2007 Here's Mr. Frog in its present build. I don't know how to do two things: #1: How do I make Mr. Frog not go through walls horizontally and yet stop on them vertically when falling down? #2: How do I make Mr. Frog not go up walls when pressing the fire button? I've tinkered with the code last night and couldn't come up with anything. mrfrog012507.bas Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted January 29, 2007 Share Posted January 29, 2007 Here's Mr. Frog in its present build. I don't know how to do two things: #1: How do I make Mr. Frog not go through walls horizontally and yet stop on them vertically when falling down? #2: How do I make Mr. Frog not go up walls when pressing the fire button? I've tinkered with the code last night and couldn't come up with anything. I kind of like that Mr. Frog can stick to the walls, although it might be good to have his shape change to be vertical instead of horizontal when he's sticking to a wall-- although I'm not sure how you could determine which direction he should be facing in. The only thing I can think of as far as preventing him from clinging to a wall is to draw the wall (or at least part of it) with the ball instead of the playfield, and then not let him cling to the ball. You could do that with only one wall per screen, though. Michael Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 29, 2007 Author Share Posted January 29, 2007 The only thing I can think of as far as preventing him from clinging to a wall is to draw the wall (or at least part of it) with the ball instead of the playfield, and then not let him cling to the ball. You could do that with only one wall per screen, though. Great idea! I'll see what I can do with the code I already have. Quote Link to comment Share on other sites More sharing options...
jbanes Posted January 29, 2007 Share Posted January 29, 2007 There's a much easier way. You've already got the playfield in memory. So just test the rectangle of the player against the pixels he will overlap when he moves along the horizontal and vertical axes. As long as you don't let him move over a playfield pixel either horizontally or vertically, he will be stopped by walls while still being able to stand on top of them. If you want to have him climb walls, you have to be a bit trickier. When you detect a horizontal collision, then you need to change the game mode to a vertical "climbing" sprite that "sticks" to the wall in question. Touching a horizontal surface (vertical collision) would reset this mode. One way of doing this would be to change the frog's gravity depending on the mode. i.e. If he's in a horizontal position, the gravity is normal top-to-bottom. When sticking on the left side of a wall, gravity for the frog would be left-to-right. Clinging on the right side of a wall would be the opposite, right-to-left gravity. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 29, 2007 Author Share Posted January 29, 2007 There's a much easier way. You've already got the playfield in memory. So just test the rectangle of the player against the pixels he will overlap when he moves along the horizontal and vertical axes. As long as you don't let him move over a playfield pixel either horizontally or vertically, he will be stopped by walls while still being able to stand on top of them. Also a great idea! How do I go about doing this? Quote Link to comment Share on other sites More sharing options...
jbanes Posted January 29, 2007 Share Posted January 29, 2007 Also a great idea! How do I go about doing this? Here is a link on rectangular collision detection: http://www.gamedev.net/reference/articles/article735.asp It's pretty straightforward stuff. If any of the four points of one rectangle fall inside the other rectangle, you have a collision. The four points are: Top Left: x, y Top Right: x + width, y Bottom Left: x, y + height Bottom Right: x + width, y + height The same formula holds true of the playfield pixels. The difference is that playfield pixels are of a fixed size, so it's easy to take the corners and test them against the playfield. All you need to do is remember that the playfield is offset from the left by 4 playfield pixels, each of which is 4 screen pixels wide. The playfield pixels heights are 8 pixels each. Which means you can find the playfield coordinates for X and Y by doing: playfieldx = x-(4*4)/4 playfieldy = y/8 Simplifying into runnable code give you: playfieldx = x - 16 playfieldx = playfieldx / 4 playfieldy = y / 8 Now that you have playfieldx and playfieldy, you can use the "pfread" function to find if the pixel is on or off. If it's on, you have a collision. If it's off, there's no collision. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 29, 2007 Author Share Posted January 29, 2007 Sorry, I'm not quite getting this. So do I put in variables at the beginning saying "dim playfieldx=q" & "dim playfieldy=p" and then run the code like that? So would I just delete the if(collision) parts and just have this code? Plus, Mr. Frog starts with a collision (he's on the ground when the game starts.) Quote Link to comment Share on other sites More sharing options...
jbanes Posted January 29, 2007 Share Posted January 29, 2007 This isn't straight-up code you can use. It's just example code to explain how it works. Giving you a full-up implementation would take too much time. More than I have, I'm afraid. A simplified explanation of the above is that you need to know what corner of the frog is on what playfield pixel. You do that by taking the X and Y of each corner and dividing it by the width and height (respectively) of the pfpixels.With that information, you can decide whether or not to commit the frog's movement, or throw it away. Yes, this would replace your existing collision detection. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted February 2, 2007 Author Share Posted February 2, 2007 (edited) Double post - read the one below this. mrfrog020207.bas Edited February 2, 2007 by atari2600land Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted February 2, 2007 Author Share Posted February 2, 2007 Argh! Stupid boulder problem! Why isn't line 607 working? player1x (w) should be going right once it's done falling off the first platform, but it's not! By the way, I sped up the game so that once you get past level 1, it goes directly to the level I'm having trouble with the boulders. Quote Link to comment Share on other sites More sharing options...
