Darius Nefarious Posted June 21, 2002 Share Posted June 21, 2002 I own an Atari heavy sixer. After I switch it on, the picture looks great for about a minute. Then wavy lines appear (it looks like interference). This happens every time I use the system. Switching it off and quickly on again gives a clear screen, but it again lasts for only about a minute until the wavy lines reappear. Has anybody encountered this problem before? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
jsoper Posted June 21, 2002 Share Posted June 21, 2002 My childhood atari started doing this. Swapped out all three IC's and the problem was still there. Went away when the console was converted to S-video output, so my theory is that it was the RF modulator. Quote Link to comment Share on other sites More sharing options...
Darius Nefarious Posted June 24, 2002 Author Share Posted June 24, 2002 Thanks so much for the info, jsoper. This prevents me from having to go through the pain of diagnosing. I'll try swapping the RF modulator. If there is a hardware FAQ out there, jsoper's information should probably be included... Quote Link to comment Share on other sites More sharing options...
Super-Genius! Posted July 3, 2002 Share Posted July 3, 2002 There is a 5 volt regulator screwed to a piece of metal on the switch board. The regulator is bad. After it heats up, it does not regulate the voltage properly. You can buy a regulator at any Radio Shack. Quote Link to comment Share on other sites More sharing options...
Osbo Posted July 6, 2002 Share Posted July 6, 2002 Hi! You might want to try the RCA Video and Audio modification (it's really easy and you find everything in Radio Shark for less than 5 bucks) and see what happends, I did it in my junior and it worked beautifull since then Just my two cents Osbo Quote Link to comment Share on other sites More sharing options...
