jbs30000 Posted March 12, 2007 Share Posted March 12, 2007 OK, so I'm working on making an Atari version of the Tron arcade game (I've completed the tank and light cycle games so far). I'm in the middle of the cone game where you shoot away the rotating blocks and enter the MPC cone. I have 4 rows of rotating blocks, the first and third rotate towards the right, and the second and fourth towards the left, but right now the block rotation is very fast and needs to be slowed down. However, whenever I try a for next loop it doesn't work, and if I use multiple for nexts then the screen flickers horribly. I can't put a drawscren inside the loops as the whole game just freezes and putting one before and one after just slows down moving the player, but the blocks still rotate too fast. All help and suggestions are welcome. Thank you. Oh, and for some reason, when you shoot, if you move your player, the missile changes direction until you stop TestBas.bas Quote Link to comment Share on other sites More sharing options...
jbs30000 Posted March 12, 2007 Author Share Posted March 12, 2007 P.S. A big well duh, but if you download this, compile it and play it. You can move the player and shoot the blocks. You'll then see how horribly fast they rotate. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 12, 2007 Share Posted March 12, 2007 Until someone is awake to help you, I wonder if this thread might be useful: http://www.atariage.com/forums/index.php?showtopic=74267 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 12, 2007 Share Posted March 12, 2007 Until someone is awake to help you, I wonder if this thread might be useful: http://www.atariage.com/forums/index.php?showtopic=74267 That's a good thread to detail one of the biggest differences between the 2600 and other platforms. Using an empty loop to consume time is pointless, because the display MUST happen at regular intervals. Instead, you check a frame counter (# of screens drawn) against another value to see if the movement portion of the game should be executed. This other value can be static, or variable amount. With the game it's based on, you'd probably want it to be a variable amount of frames to skip movement on (so it gets faster as you progress to higher levels). If you already have a level counter set up, this wastes no additional ram...you could just read the check value from a table in rom (using the level # as an index). Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 12, 2007 Share Posted March 12, 2007 Oh, and for some reason, when you shoot, if you move your player, the missile changes direction until you stop From first glance, it appears that your player movement lines are causing it: PlayerLeft player0x = player0x - 1: missile1x = missile1x - 1 if joy0up then Sprite_PTR = 0: goto West else Sprite_PTR = 1: goto NorthWest PlayerRight player0x = player0x + 1: missile1x = missile1x + 1 Since the missile's initial location is already set up when you fire, is there any particular reason that updates are happening on these lines? Quote Link to comment Share on other sites More sharing options...
jbs30000 Posted March 12, 2007 Author Share Posted March 12, 2007 Until someone is awake to help you, I wonder if this thread might be useful: http://www.atariage.com/forums/index.php?showtopic=74267 Thanks, I'll take a loot at it. Quote Link to comment Share on other sites More sharing options...
jbs30000 Posted March 12, 2007 Author Share Posted March 12, 2007 Until someone is awake to help you, I wonder if this thread might be useful: http://www.atariage.com/forums/index.php?showtopic=74267 Thanks, I'll take a loot at it. er, look at it, I mean. Quote Link to comment Share on other sites More sharing options...
jbs30000 Posted March 12, 2007 Author Share Posted March 12, 2007 Until someone is awake to help you, I wonder if this thread might be useful: http://www.atariage.com/forums/index.php?showtopic=74267 That's a good thread to detail one of the biggest differences between the 2600 and other platforms. Using an empty loop to consume time is pointless, because the display MUST happen at regular intervals. Instead, you check a frame counter (# of screens drawn) against another value to see if the movement portion of the game should be executed. This other value can be static, or variable amount. With the game it's based on, you'd probably want it to be a variable amount of frames to skip movement on (so it gets faster as you progress to higher levels). If you already have a level counter set up, this wastes no additional ram...you could just read the check value from a table in rom (using the level # as an index). Right now I'm keeping things,well basic, no pun intended. For the moment all the games don't get harder, you either win or lose and then go back to the main screen where you can choose to play them again. After I finish this and the spider game I'll post the whole thing, then go back and rewrite the code for each game, pretty much from scratch to make it more efficient (the tank code is horribly bloated) and to make each level harder. Anyway, I think using a frame checker will help solve another problem I've been trying to figure out. I've been trying to figure out how to time the cone dropping downwards like it does in the arcade game. Thanks. Quote Link to comment Share on other sites More sharing options...
jbs30000 Posted March 12, 2007 Author Share Posted March 12, 2007 Oh, and for some reason, when you shoot, if you move your player, the missile changes direction until you stop From first glance, it appears that your player movement lines are causing it: PlayerLeft player0x = player0x - 1: missile1x = missile1x - 1 if joy0up then Sprite_PTR = 0: goto West else Sprite_PTR = 1: goto NorthWest PlayerRight player0x = player0x + 1: missile1x = missile1x + 1 Since the missile's initial location is already set up when you fire, is there any particular reason that updates are happening on these lines? D'oh! That's code that was supposed to be eliminated earlier on. Guess I wasn't paying enough attention. Thank you. Quote Link to comment Share on other sites More sharing options...
