Room 34 Posted June 25, 2002 Share Posted June 25, 2002 I've recently taken the plunge and opened up my 2600s. (I learned that this is much easier to do on a 4-switch than a 6-switch, and that putting a 6-switch back together is nearly impossible, at least for my coordination-challenged hands and brain.) Anyway, I found, in all 3 of my systems (a 6-switch Sears, 4-switch woodgrain and Darth Vader), a little piece of paper taped onto the shielding box. On all of them the adhesive on the tape was completely disintegrated, so I took them off before closing up the consoles. Each piece of paper is stamped with what I presume is the date of manufacture. The 6-switch was stamped 14 MAR 1981 (my 7th birthday, incidentally). The 4-switch woody (my original system from 1982) was stamped 7 JAN 1982. Now when I get to the Darth Vader is where it gets confusing. Both of my other systems were manufactured by Dimerico (sp?) but the Vader was made by a different company (starts with a K -- I can't remember the exact name now). The paper on the Vader was stamped 72 . 10 . 28 which has me somewhat baffled. I am guessing this is some kind of code where the numbers are backwards, which would lead to a date of January 27, 1982. But that can't be right because I am fairly certain the Vader units were not made until much later in 1982. So is it October 27, 1982? Quote Link to comment Share on other sites More sharing options...
