y-bot Posted March 24, 2007 Share Posted March 24, 2007 I just got one of these today and I can't get it to work. The 5200 controller works when hooked up to it and switching the analog controller on/off switch works. A working 2600 controller does nothing. I don't have the instructions, is there something I'm missing? If it is broken can it be fixed? I was pretty excited to finally get one of these and now I'm bummed out. y-bot Quote Link to comment Share on other sites More sharing options...
jsoper Posted March 27, 2007 Share Posted March 27, 2007 There's only two CD4016 analog switch chips in a masterplay. Just cut the chip pins, remove each pin and clean the holes with solder wick, then solder in two new 4016 (or 4066) chips. Quote Link to comment Share on other sites More sharing options...
y-bot Posted March 28, 2007 Author Share Posted March 28, 2007 Thanks for the info. is there any possibility I'm doing something wrong? Do these go bad often? y-bot There's only two CD4016 analog switch chips in a masterplay. Just cut the chip pins, remove each pin and clean the holes with solder wick, then solder in two new 4016 (or 4066) chips. Quote Link to comment Share on other sites More sharing options...
