+Guitarman Posted April 2, 2007 Share Posted April 2, 2007 Unfortunately, I just broke off pin 13 on one of my 800's I am working on. Pin 13 is described as 'interrupt (active low)'. So far, everything I have read on the SIO port states that it has never been utilized by any peripherals. Is this the case??? If so, I'll leave it alone. If not, I will have to change it out. Quote Link to comment Share on other sites More sharing options...
classics Posted April 2, 2007 Share Posted April 2, 2007 Unfortunately, I just broke off pin 13 on one of my 800's I am working on. Pin 13 is described as 'interrupt (active low)'. So far, everything I have read on the SIO port states that it has never been utilized by any peripherals. Is this the case??? If so, I'll leave it alone. If not, I will have to change it out. As far as I know nothing uses it. Steve Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted April 2, 2007 Author Share Posted April 2, 2007 Thanks Steve. It's good to know. I already switched out the SIO connector but at least I know I can use the one with the broken pin if need be down the road. Quote Link to comment Share on other sites More sharing options...
a8maestro Posted April 6, 2007 Share Posted April 6, 2007 Unfortunately, I just broke off pin 13 on one of my 800's I am working on. Pin 13 is described as 'interrupt (active low)'. So far, everything I have read on the SIO port states that it has never been utilized by any peripherals. Is this the case??? If so, I'll leave it alone. If not, I will have to change it out. So far the only thing I know that uses pin 13 are the rverter 1(AID) and rverter 2 interfaces, for the Ring Indicate from modems. I have not implemented this or tested it. a8maestro Quote Link to comment Share on other sites More sharing options...
