Nico95 Posted April 10, 2007 Share Posted April 10, 2007 I'm trying to find were I can get a Security bit for a old Atari Super Pong. I have had no luck with pliers or visegrips or any other method so far. I would like to try to find out were to get the bit. Best Electronics didn't carry them and thought they were around $10 if I could find one. It would be nice at least to know the name of the bit. Also does anyone have a spare Battery compartment for a superpong laying around. Mine is totally shot and would like to fix that with a replacement. THanks! Nick Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted April 10, 2007 Share Posted April 10, 2007 Northern Tools sells them, you can also check happcontrols.com Curt Quote Link to comment Share on other sites More sharing options...
Nico95 Posted April 10, 2007 Author Share Posted April 10, 2007 Northern Tools sells them, you can also check happcontrols.com Curt THanks Curt, What is the actual Name of the bit, so I can look it up? Thanks again, Nick Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted April 11, 2007 Share Posted April 11, 2007 Lookup or request a security bit set. Curt Northern Tools sells them, you can also check happcontrols.com Curt THanks Curt, What is the actual Name of the bit, so I can look it up? Thanks again, Nick Quote Link to comment Share on other sites More sharing options...
Nico95 Posted April 15, 2007 Author Share Posted April 15, 2007 I checked out the security bit sets, but of know of them looks to have a bit that would fit. It's like a tri wing with a indented center. Really more like a spanner with three pieces instaed of 2. At least thats how it should look. A regular spanner won't work either. I've checked all my security bit sets also. No luck. Any all help is greatlly appreciated. I'll send a pic. Maybe mines is diiferent . Hope this helps. Again thanks for your help. Hopefully I can track something down. It would be nice. Thanks again, Nick Lookup or request a security bit set. Curt Northern Tools sells them, you can also check happcontrols.com Curt THanks Curt, What is the actual Name of the bit, so I can look it up? Thanks again, Nick Quote Link to comment Share on other sites More sharing options...
+batari Posted April 15, 2007 Share Posted April 15, 2007 I've never seen a bit like that, and I've got a 100-piece set. My advice: Try vice grips. If you can't grip it, make a notch in the center of the screw's head with a center punch and drill it out. When you're done, replace with a regular screw. Quote Link to comment Share on other sites More sharing options...
Nico95 Posted April 16, 2007 Author Share Posted April 16, 2007 I've never seen a bit like that, and I've got a 100-piece set. My advice: Try vice grips. If you can't grip it, make a notch in the center of the screw's head with a center punch and drill it out. When you're done, replace with a regular screw. Yeah, It's not a easy thing to find. I've checked those 100 piece one's too. no luck. I really hate to drill it. I'm a purist what can I say,lol. I thought I saw one a long time ago on my old Dodge Diplomat Radio. It sure looked similar. I haven't had any luck with vise grips either. You wouldn't happen to know a good place for a replacement Battery compartment. I never can find these on Ebay as parts/ Repair. Wasn't sure if ther was anyone out there that had parts like B&C or Best. Best doesn't for sure, and didn't see anything on B&C either. Funny thing is Grad from Best seemed to know what it was but didn't have a name for the bit when I checked with him about 2 years ago. Thanks again, Nick Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted April 16, 2007 Share Posted April 16, 2007 Wow, that's an odd one. If the actual bit can't be found, I might try to find a tri-wing bit that's close, and use a dremel to grind out the center (maybe cut the tip off straight first, if it looks like the indentations in the screw head all share a flat plane at the bottom). Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted April 16, 2007 Share Posted April 16, 2007 It's a pong set, DRILL IT! Quote Link to comment Share on other sites More sharing options...
david.winter Posted August 25, 2007 Share Posted August 25, 2007 I too had troubles opening my own systems but the only solution I found so far was to grip the screws using a wire grip (wire cuter). This requires a bit of patience but you end up removing the screws. Then I would saw a line on the top of the head so that normal screw drivers would then work. In the other hand I found some systems with different screws with a square hole on the center of their tops. A normal flat screw driver will work fine. Quote Link to comment Share on other sites More sharing options...
BigO Posted August 28, 2007 Share Posted August 28, 2007 Depending on the tools you have available and the accessibility to the screw head, is there some way to just cut a straight slot in the head? Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted August 31, 2007 Share Posted August 31, 2007 That looks like the same screwhead used on many EA Genesis carts. The thing about it is that unlike a regular twi-wing, the indents are on the outside of the head where you get more leverage. You just need an awl or something to push the screw near the outside edge. Once I get that kind of screw off I don't put it back. Quote Link to comment Share on other sites More sharing options...
Richard H. Posted August 31, 2007 Share Posted August 31, 2007 I once read about an arcade repair guy who used a ball point pen (minus the ink). He heated it up and then placed it over the screw-head. The idea being that the plastic moulded itself around the screw head, and once set, was enough to loosen the screw. I suppose it all depends on how tight in the original is though. Quote Link to comment Share on other sites More sharing options...
Lemmi Posted August 31, 2007 Share Posted August 31, 2007 i have taken apart a few things with that type of screw and i found that this bit will sometimes do the trick if its not to tight i have this type of screw on a recliner chair i have in the living room and i used this bit to tighten a few screws here is my set and i took the bit out that i use for these types of screws, if the gap between the bit is large enough you can get the points to attach to 2 parts of the screw and turn it and my nes bits are in the screwdriver handle Quote Link to comment Share on other sites More sharing options...
