Scott Stilphen Posted June 30, 2002 Share Posted June 30, 2002 Is it possible to dump the interal GameLine Master code and run it on an emu? Quote Link to comment Share on other sites More sharing options...
Eckhard Stolberg Posted July 2, 2002 Share Posted July 2, 2002 The Gameline cartridge probably uses it's own bankswitching scheme. So unless you want to open your cartridge and unsolder the chip for having it dumped, it would probably take some experimentation and code changing in the cartridge reader to have the ROM dumped properly. The Gameline also has to use a special way of writing to it's RAM, so changes to the emulators would also be nessesary. Then it might be possible to have it display the Gameline title screen etc. Adding support to the emulator for the hardware accesses to the internal modem in the Gameline is probably not worth it. It would be nice to have a look at that code anyway though. Do you have a Gameline modem, that the ROM could be read from? Ciao, Eckhard Stolberg Quote Link to comment Share on other sites More sharing options...
slapdash Posted July 2, 2002 Share Posted July 2, 2002 If the Gameline were emulatable, you could probably also add a way to drop in a new phone number, and could then actually use your Gameline, virtually. Or hack the BIN and use the Cuttle Cart??? Quote Link to comment Share on other sites More sharing options...
Scott Stilphen Posted July 2, 2002 Author Share Posted July 2, 2002 I don't have one, sorry. Quote Link to comment Share on other sites More sharing options...
