+Larry Posted April 29, 2007 Share Posted April 29, 2007 Is the cartridge slot on a 1200 XL large enough to accomodate pretty much any Atari cartridge? Does anyone use a 1200 XL with the AtariMax MyIde Flashcart + compact flash? Enough room for that? I'm considering buying a 1200 XL, and since there is no PBI, I'd probably be using the MyIDE. I could install an internal interface, but probably prefer the cart. If there are any interested U.S. /Canadian sellers (due to postage), send me a PM -- nice, fully working units only, please. I will respond to all PM's. -Larry Quote Link to comment Share on other sites More sharing options...
jdh Posted April 29, 2007 Share Posted April 29, 2007 I sometimes use my 1200XL with the MyIDE Flashcart and IDE Transcend module, works fine with that. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 1, 2007 Share Posted May 1, 2007 I'm going to run with 1200XL post I have a extra 50 pin SCSI Hard Drive what do I need to use it with my 1200XL? Quote Link to comment Share on other sites More sharing options...
LYNXGUY Posted May 6, 2007 Share Posted May 6, 2007 My bet friend has a 1200XL and he needed to run what is called FIXXL program in order to play some games and the only carts he had trouble with was the any K-razy carts games, like K-razy antics, K-razy shootout there are more K-razy games but i can't remember off hand. If I remember correctly the K-razy games carts didn't fit quite right and you if put push them in a bit to snug the games wouldn't work however any other cart would work fine. Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 8, 2007 Author Share Posted May 8, 2007 Thanks! Yes, I'm sure there are likely a few third-party carts that just won't fit. I have a K-Star Patrol cart, but that's no biggie. But I've measured my MVC's (most valuable cartridges) -- the ICD "SuperCarts" and they should fit just fine. And using the MyIDE with the Transcend flash module is an excellent suggestion. -Larry Quote Link to comment Share on other sites More sharing options...
Tempest Posted May 8, 2007 Share Posted May 8, 2007 I had trouble fitting some 3rd party carts into my 1200xl. I thought about sanding down the inside of the cartridge slot, but I read you can use any "passthrough" cart to get around the issue so I may use my R-Time8 cart instead. The OS still has some problems with certain games, but thankfully my modded 1200xl has 4 different OS's to choose from. Tempest Quote Link to comment Share on other sites More sharing options...
