walter_J64bit Posted May 2, 2007 Share Posted May 2, 2007 Is there any SCSI adapters Atari 1200XL and where do I get one? Quote Link to comment Share on other sites More sharing options...
charliecron Posted May 2, 2007 Share Posted May 2, 2007 Well without adding a PBI back into the 1200xl and getting yourself a blackbox, I don't think your going to get a SCSI hard disk going on your 1200xl, at least with a SCSI interface, but I could be wrong. If you really want add a PBI back into your 1200XL, http://www.retrobits.net/atari/pbi.shtml Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 2, 2007 Author Share Posted May 2, 2007 (edited) Well without adding a PBI back into the 1200xl and getting yourself a blackbox, I don't think your going to get a SCSI hard disk going on your 1200xl, at least with a SCSI interface, but I could be wrong. If you really want add a PBI back into your 1200XL, http://www.retrobits.net/atari/pbi.shtml WOW, that is a lot of work Edited May 2, 2007 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted May 2, 2007 Share Posted May 2, 2007 WOW, that is a lot of work The MyIDE cart from AtariMax & Mr Atari is an easy Hard Disk solution if you don't need to run SpartaDOS. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 2, 2007 Author Share Posted May 2, 2007 WOW, that is a lot of work The MyIDE cart from AtariMax & Mr Atari is an easy Hard Disk solution if you don't need to run SpartaDOS. Hmmm, I'll look in to that. Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 2, 2007 Share Posted May 2, 2007 Hello folks The MyIDE cart from AtariMax & Mr Atari is an easy Hard Disk solution if you don't need to run SpartaDOS. The MyIDE cart is not SCSI but IDE. And only uses 8 bits. Meaning stuff like CDROM drives are out of the question. Greetings Mathy Quote Link to comment Share on other sites More sharing options...
