Heaven/TQA Posted May 13, 2007 Share Posted May 13, 2007 what is your fave "seed based" random routine? i am using this one for generating level maps so it should be able to recreate the sequenze: _get_Random: ;cld _rand inc rnd2 lda rnd2 clc adc rnd1 adc rnd2 sta rnd1 eor rnd2 sta rnd2 sbc rnd0 sta rnd0 rts rnd0 dta 0rnd1 dta 0rnd2 dta 0 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 13, 2007 Share Posted May 13, 2007 I prefer LSFRs: lda random lsr bcc .skipEor eor #$b2 .skipEor sta random Just 8 bits, but works similar with 16 or more bits too. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 13, 2007 Author Share Posted May 13, 2007 (edited) thanks Thomas, where do i store the starting seed (=level # of the map)? i guess random? ;=)? Edited May 13, 2007 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 13, 2007 Share Posted May 13, 2007 Not sure if I get you. Just load random with the initial value for that level. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 14, 2007 Author Share Posted May 14, 2007 but thomas. looking at your code... what happens when random=0? i mean for me it will skip the EOR forever so it will stay at 0? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 14, 2007 Share Posted May 14, 2007 but thomas. looking at your code... what happens when random=0? i mean for me it will skip the EOR forever so it will stay at 0? Unless initialized with 0, this will never happen (bit 7 is always set with EOR). BTW: There are several "good" EOR values, resulting into a 255 different values sequence. Info here: http://www.ece.cmu.edu/~koopman/lfsr/ Quote Link to comment Share on other sites More sharing options...
supercat Posted May 15, 2007 Share Posted May 15, 2007 BTW: There are several "good" EOR values, resulting into a 255 different values sequence. I prefer to use a 16-bit randomizer, with one half shifting right and the other shifting left. That avoids some of the patterns that may otherwise appear. Another approach is to XOR the output of the randomizer with some other variable. This will also help avoid many types of patterns. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 15, 2007 Author Share Posted May 15, 2007 supercat. any code example? Quote Link to comment Share on other sites More sharing options...
+batari Posted May 15, 2007 Share Posted May 15, 2007 (edited) supercat. any code example? This is a 16-bit LFSR that uses Supercat's suggestions: randomize lda rand lsr rol rand16 bcc noeor eor #$B4 noeor sta rand eor rand16 rts You need two bytes, rand and rand16. You can seed this routine with anything except two zeros. To use it, just JSR there and you get a random byte in the accumulator. Edited May 15, 2007 by batari Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 15, 2007 Share Posted May 15, 2007 This is a 16-bit LFSR that uses Supercat's suggestions: Not a very good LFSR, since it doesn't eor rand16 and the generated sequence is (probably much) shorter than 2^16-1. Taking a good 16 bit value from the link I posted above, mirroring the high byte and eoring that one too would result into better randoms. Though I doubt shifting in different directions or eoring high and low bytes makes the result any more random. NextRandom SUBROUTINE lda randHi lsr ror randLo bcc .skipEor eor #HI_EOR sta randHi lda randLo eor #LO_EOR sta randLo .skipEor: lda randLo BTW: Actually a LFSR generates just one single bit with each iteration. The other bits are depending on each other somehow. Quote Link to comment Share on other sites More sharing options...
+batari Posted May 15, 2007 Share Posted May 15, 2007 This is a 16-bit LFSR that uses Supercat's suggestions: Not a very good LFSR, since it doesn't eor rand16 and the generated sequence is (probably much) shorter than 2^16-1. Taking a good 16 bit value from the link I posted above, mirroring the high byte and eoring that one too would result into better randoms. Though I doubt shifting in different directions or eoring high and low bytes makes the result any more random. It actually is 65535 bytes long. And while rand16 isn't eor'ed with a constant, its result isn't intended to be used as a random number. Shifting opposite directions doesn't make it more random, but the eor at the end does reduce the correlation with previous values according to random number tests (and this routine had excellent results from said tests.) Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 15, 2007 Share Posted May 15, 2007 It actually is 65535 bytes long. And while rand16 isn't eor'ed with a constant, its result isn't intended to be used as a random number. I stand corrected. (notes to himself: next time check the complete list!) but the eor at the end does reduce the correlation with previous values according to random number tests (and this routine had excellent results from said tests.) Do you have any links? I am really interested. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 15, 2007 Share Posted May 15, 2007 I did some tests with Ent. Supercats sequence is no better than a normal 16 bit sequence, except for sequence correlation. There is is much better than the normal LFSR! Quote Link to comment Share on other sites More sharing options...
DEBRO Posted May 16, 2007 Share Posted May 16, 2007 but thomas. looking at your code... what happens when random=0? i mean for me it will skip the EOR forever so it will stay at 0? Unless initialized with 0, this will never happen (bit 7 is always set with EOR). BTW: There are several "good" EOR values, resulting into a 255 different values sequence. Info here: http://www.ece.cmu.edu/~koopman/lfsr/ If you do bcs instead of bcc then you will get 255 values regardless of the seed being 0. I wrote a test for this that spit out the 255 values (or was it 256...I can't remember). Quote Link to comment Share on other sites More sharing options...
supercat Posted May 16, 2007 Share Posted May 16, 2007 Supercats sequence is no better than a normal 16 bit sequence, except for sequence correlation. There is is much better than the normal LFSR! If you generate 8 bit random numbers by using half of a normal 16-bit LFSR, or the XOR of the top and bottom halves, then after some value is output the next number can only have one of two values (based upon whether the other half of the generator shifts out a '1'). By contrast, when using opposite-direction shifts, any value may be output after any other value, except that a zero will not follow another zero. The only "ugliness" in the generator occurs when it outputs the sequence (128,64,32,16,4,2,1,1,2,4,8,16,32,64,128). Depending upon what the generator is being used for, XORing the output with a constant like $B3 may make that pattern less objectionable. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 17, 2007 Author Share Posted May 17, 2007 i will use the random routines for building level maps... i will see how they perform at the end of the day. Quote Link to comment Share on other sites More sharing options...
