undeadmechanic Posted May 21, 2007 Share Posted May 21, 2007 Ok, first, I must bore you with a bit of history. Years upon years ago I stumbled upon an Astra 1620 floppy drive in a pawn shop for 5 bucks (the guys there had NO idea what system it was for) & snatched that puppy up. I played with it back in the day, even used it as my sole drive(s) for quite some time. Then, the gremlins got it. Very erratic reads, so I mothballed it. Then, like 7 years ago, I packed up and moved to Dallas and left my beloved A8 behind. Some time passed, then I came home and retrieved my collection and took it back to Dallas with me, however, I could not find my Astra 1620. A short time later, I met Dr. Clu and my fondness for collecting Atari crap went into overdrive. Now, I have moved back to Arkansas and set up shop here again. Just this morning, I located my Astra in the attic buried under a pile of old newspapers & photo albums. My heart skipped, I jumped for joy, and nearly fell through the ceiling... Much to my chagrin, I have spent the last couple of hours looking for info on Astra drives, and so far I have not found anything other than reviews and comparisons to other drives. I need to know if ANYBODY knows where I can get a tech sheet, specs, or anything on this drive. The drive is useless when compared to my XFs and Indus GTs, but it's in my collection for a reason. I wanna at least try to resurrect it. Just point me in the right direction, and if that doesn't work, I'll start picking brains on here... Thanks, David Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 21, 2007 Share Posted May 21, 2007 Ok, first, I must bore you with a bit of history. Years upon years ago I stumbled upon an Astra 1620 floppy drive in a pawn shop for 5 bucks (the guys there had NO idea what system it was for) & snatched that puppy up. I played with it back in the day, even used it as my sole drive(s) for quite some time. Then, the gremlins got it. Very erratic reads, so I mothballed it. (snip...) I need to know if ANYBODY knows where I can get a tech sheet, specs, or anything on this drive. The drive is useless when compared to my XFs and Indus GTs, but it's in my collection for a reason. I wanna at least try to resurrect it. Just point me in the right direction, and if that doesn't work, I'll start picking brains on here... Thanks, David Unfortunately I do not have any Astra tech docs, but I do remember that some used the pull-down mechanisms. Does yours? If so, I'd try swapping one out for a standard (Tandon-type) 5-1/4" mech. Also, some of those pull-down mechs had issues with emi. How are the belts? Other than general tune-up stuff, that's all I can think of for now. -Larry Quote Link to comment Share on other sites More sharing options...
