+atari2600land Posted May 22, 2007 Share Posted May 22, 2007 I'm not sure if this is Batari Basic's fault or not, but I'm using Windows to use 2600IDE/bB, and is there a way to have the black DOS screen that comes up last more than a nanosecond before it disappears and the thing that tells you how many bytes you have left in your program with two buttons to click on pop up? (Excuse my lack of technical terms.) Quote Link to comment Share on other sites More sharing options...
CurtisP Posted May 23, 2007 Share Posted May 23, 2007 I'm not sure if this is Batari Basic's fault or not, but I'm using Windows to use 2600IDE/bB, and is there a way to have the black DOS screen that comes up last more than a nanosecond before it disappears and the thing that tells you how many bytes you have left in your program with two buttons to click on pop up? (Excuse my lack of technical terms.) What I did was to add a PAUSE at the end of 2600baside.bat (on the line after ":END"). Then you can see what ever happens to appear in the DOS box, then press Enter to continue on to the 2600IDE dialog box. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted May 23, 2007 Author Share Posted May 23, 2007 Thank you! I had a little trouble finding it (it's an MS-DOS batch file), then I had trouble opening it (right clicking and then choosing 'edit'). But anyway, I did it and I like it. Thanks again! Quote Link to comment Share on other sites More sharing options...
