SeaGtGruff Posted May 25, 2007 Share Posted May 25, 2007 I've been working on a game for someone, but I've run into problems with positioning the multisprite players near the bottom of the screen. The following test program demonstrates what's happening. The sprite (which is just a single line for this little test) should drop down the screen, keeping the same x position all the way down-- but as it nears the bottom of the screen, it shoots over toward the middle of the screen (presumably to where player1 is positioned for the score?). includesfile multisprite.inc set kernel multisprite player1: %11111111 end player1x = 8 player1y = 85 _COLUP1 = $1A loop drawscreen player1y = player1y - 1 if player1y = 3 then player1x = 8 : player1y = 85 goto loop Is this a bug in the multisptite kernel? Michael Quote Link to comment Share on other sites More sharing options...
+batari Posted May 25, 2007 Share Posted May 25, 2007 Is this a bug in the multisptite kernel? I'm afraid so, but it only occurs under very specific circumstances, i.e. when the top of a sprite is more than a few lines below the top of the lowest playfield block. In most games, you will never see this bug. If you pfheight=3 or less, you will never see the bug. Or if you use pfheight=7 and all of your sprites are more than a 4 or 5 lines tall. Of course I'll look into fixing it, but for now, it's easy to avoid and most games probably won't encounter it. Quote Link to comment Share on other sites More sharing options...
+batari Posted May 25, 2007 Share Posted May 25, 2007 I think this might fix it. The problem seems to have been a page-wrapping issue. The fix adds 4 bytes to the kernel. msk_5_25_07.zip Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 25, 2007 Author Share Posted May 25, 2007 I think this might fix it. The problem seems to have been a page-wrapping issue. The fix adds 4 bytes to the kernel. Yes, that seems to have fixed it. Thank you, batari! Now I can get back to working on that game. Michael Quote Link to comment Share on other sites More sharing options...
