Go To Your Room!
atari2600land
While taking a break from Halloween Havoc, I tried to make an Adventure-styled world. But I've run into a bit of a snag because it won't recognize rooms 7-9 as actual rooms (see code), even though they have exactly the same coding as the other rooms. Why is this? Here's a map of the world (it's a small world, after all)
b equalling 1 or 2 is for programming purposes.
adv.bas
There were two problems:
(1) b wasn't always being set to 1 or 2 whenever you switched areas, and
(2) the order of some of the ifs caused a to be updated more than once.
A simple way to fix (2) would be to just add a goto at the end of each if to jump over the other ifs, but I was able to correct it by just rearranging them a bit.
Michael
adv.bas
adv.bas.bin
  • 2 weeks later...
OK, now suppose I want player0 to appear in a random room. I tried this:
	player0:
11110
end
decide_c
c=rand
if c=0 then goto decide_c
if c>10 then goto decide_c
if c=1 then goto decide_d
if c=2 then d=1 : goto main
if c=3 then d=1 : goto main
if c=4 then d=2 : goto main
if c=5 then d=2 : goto main
if c=6 then goto decide_d
if c=7 then d=1 : goto main
if c=8 then d=2 : goto main
if c=9 then goto decide_d
goto main
decide_d
d=rand
if d>128 then d=1
if d<=128 then d=2
and then put
if a=c && b=d then player0x=e : player0y=f (e and f are two values I determined
at the start of the game)
but if it appeared at all, it would only be in a few of them. What am I doing
wrong?
Edited by atari2600land
I figured out that problem. :dunce: I shouldn't be thinking when it's too hot. But now I have a new problem: Mr. Enemy Block is showing up at the top when he's supposed to be in the center of the screen. I think the problem lies in the get_g part. I think I got confused because there's no drawscreen and I'm trying to get a sprite to appear, and well, here.
adv3.bas
